Old 11-25-2001, 02:29 PM   #1 (permalink)
Cemo's Avatar
I broke my tranny...again...
I've only put 4500 miles since I had my tranny rebuilt for the first time and it's happened again. The way it went was very unlike the first time where the syncros started to grind until it finally stopped shifting right. This time I left hard, powershifted second and then BLAM! The car was well into second gear and it just broke
Symptoms: neutral in all gears w/ a bit of grinding noises. I don't think I shattered any gears, just screwed up the forks or synchros again. It is such a nice day I'm not gonna let it get to me.
I had the car flat bedded over to MTI where I will have Jeff fix it again. I hope it's nothing too bad. I'd like to have her back before next weekend.
#2 going on #3...
1999 Torch Red Hardtop | MTI H/C | 426 & 400 Rw | 11.88 @ 121 Mph w/ 1.91 60'
Cemo is offline   Reply With Quote
Old 11-25-2001, 03:12 PM   #2 (permalink)
Hope you get it back up and running again soon.
Frank QS/Black 2001 Z06
Katech Stage II Heads and Cam, Katech Ported and Polished Throttle Body, 36# Injectors, FLP Headers, High Flow Cats and X-Pipe, Vortex Rammer & Power Duct, BPP Performance Shifter, MSD Wires, Beru Spark Plugs, Lloyds Mats, Chrome Z06 Wheels, Euro Tail Lights
....I AM BONE STOCK!!
Sherylann BLK/Black 2001 Z06
Vortex Rammer & Power Duct, Chrome Z06 Wheels, Lloyds Mats, Shortened stock shifter with MOMO knob
fcalmes is offline   Reply With Quote
Old 11-25-2001, 03:42 PM   #3 (permalink)
Send a message via AIM to sigung86
Sorry Bub!
HallTech TRIC, B&M Ripper Shifter, MGW Anodized Pistol Grip shift knob, Stainless Screens, Illuminated Red Fuzzy Dice, Blue-yellow-green Scooby-Doo Steering Wheel Cover courtesy of my 5 year old grandson.
sigung86 is offline   Reply With Quote
Old 11-25-2001, 03:45 PM   #4 (permalink)
Cemo's Avatar
Thanks guys...
I know I'm gonna be dealing with transmission problems/failures with my style of driving but, damn, this one didn't last near long enough.
Old 11-26-2001, 11:54 AM   #5 (permalink)
Send a message via AIM to FlyinBrian
Backup Tranny:
I saw this for sale on another site thought you might be interested
http://forums.corvetteforum.com/zerothread?id=189490
Originally posted by Cemo
Thanks guys...
Brian
'00 Nassau Blue FRC
ARE 436 LS6 Stroker,Yella Terra Rockers,CompCams 236/242-601/610-114,Ron Davis Rad w/ Internal Oil Cooler,Exedy Twin Disc Clutch,DTE 3.90s w/Hardened Output Shaft,DTE Differential Strut,Custom Built 1 3/4"-1 7/8" Stepped Headers,Custom 3" mid pipe w/crossover,CCWs w/ ET Streets & Skinnies,QA1 Drag Shocks,Wolfe 6 Point Roll Bar w/Removable Door Bars
Wideband 02,LS1-Edit,Installed & Tuned By Me
FlyinBrian is offline   Reply With Quote
Old 11-26-2001, 02:21 PM   #6 (permalink)
Cemo's Avatar
Thanks Brian!
Old 11-26-2001, 03:01 PM   #7 (permalink)
Thanks Brian!
Your quite welcome
Old 11-27-2001, 08:00 AM   #8 (permalink)
Ernie King's Avatar
Cemo,
Did you get your traany fixed? What happened to it.. And what the H**** did you do to break it?
Hope it's ok now.....
Ernie
2000 FRC Nassau Blue
10 Second Club
Old 11-27-2001, 08:39 AM   #9 (permalink)
Cemo's Avatar
Ernie- Yes, I had the tranny rebuilt already once at 20k miles. I damages the 3rd-4th gear synchros. At first, the tranny would grind during that shift only when powershifting but after a while it started to grind all the time no matter how hard I shifted. Eventually it would not shift at all, any gear, without major effort. MTI did a good job and had me back on the road with M12 replacement synchro parts.
This time it looks like I broke the input shaft. This is only a preliminary diagnosis because the tranny won't be out of the car again until later this week. I have ordered a steel fork for 3rd-4th gear. It will be installed along with whatever else is needed, hopefully just a replacement input shaft.
I'm known for breaking trannies all the time because I beat the hell out of them when racing. I practice the "no lift shift" technique. There is too much mass envolved to get away with it for a long time. Thanks to Brian I should have a backup M6 on the way real soon. That one will get sent off the Liberty Transmission for a full beef up.
Old 12-07-2001, 12:30 PM   #10 (permalink)
Cemo's Avatar
Disassembly is done!
Diagnosis: The main/top shaft of transmission is snapped in two
Prognosis: With 'Vette withdrawl at maximum levels, a ray of sunshine has broken through the dense fog that covers Brokenvetteland. Next 'Vette "fix" should be in a week or less
Notes: I have been quoted ~$300 for the shaft. I'm gonna add a steel 3rd-4th shift fork from D&D Perf., an unrestricted master cylinder line and all new synchros during this rebuild.
I have been doing a lot of research on upgrade parts/mods that are available for the T-56. If you'd like to see the results lemme know and I'll post 'em.
Old 12-07-2001, 12:53 PM   #11 (permalink)
Glad to hear things are getting better!!!
Like I've said before, "If you weren't so far away I'd come down and give you a ride".
Looks like, just in time for Christmas Quarter Miling.
Old 12-08-2001, 08:55 AM   #12 (permalink)
Cemo, maybe you should consider this:
http://www.lencoracing.com/st12.html
On a serious suggestion, I think Jerico has some beefy pieces for the straight cut gear fans. I have some experience with their racing stuff. They make REAL racing transmissions. It's them and Hewland as far as I'm concerned.
The Jerico five speeds are noiser than a Muncie "rock crusher" but they are hard to break. The drag racing trannie requires double clutching to downshift smoothly, at least the one I drove did. Their roadracing tranny is no doubt a better shifter in the twisties. It shifts a fast as you do. I had a chance for a spin in a TransAM car with this trannie and it is SWEET SWEET.
You can talk to Jerico and they might have some suggestions, they are EXCELLENT and their site includes pricing info too:
http://www.jericoperformance.com/
or maybe...
SVSI offers some upgrade stuff for T56 viper dudes.
I'm not involved with Viper racing stuff so I don't have any experience dealling with these folks, just know they are out there.
Scroll down once you get here:
http://www.supervipersystems.com/Per...driveline.html
1fastdog is offline   Reply With Quote
Old 12-08-2001, 09:32 PM   #13 (permalink)
Cemo's Avatar
Brian- I started a new thread in here for info and further discussion
1fast- As you'll see from my new post you were spot on with your suggestions. SVSi is a company that I'm currently talking to about upgrade parts and a possible Jerico 5-speed for our cars!
Old 12-08-2001, 09:53 PM   #14 (permalink)
Great!
I think I broke it! What should I do? D-man C5 Z06 - Pit Road 17 10-31-2003 10:33 AM
Want to swap Z06 tranny for "regular" C5 tranny? Redshift C5 Z06 - Grandstand 48 12-04-2002 06:57 AM
Tranny Broke ZO6/Les C5 Z06 - Pit Road 31 11-20-2002 04:46 PM
Broke into the Z :( obi2001 C5 Z06 - Grandstand 17 06-26-2002 09:00 PM
Oh no. I think I broke my tranny! Zee Freak C5 Z06 - Pit Road 9 05-01-2002 03:59 PM
