Don't know.
The tire pressure sensor unit is built in to the valve stem. There are two types - the "old" and the "new." That was simply some sort of change (different manufacturer??? - the new ones are less expensive to replace) that they made in 2000 (I think that was the year) and compatability depends on the year of your vehicle rather than model. If you have Z06 wheels that are the wider versions like came on them rather than the "look-alikes" that come in the standard widths, then the sensors may not read correct pressures, but they will work. They are independent of the wheel manufacturer, but apparently volume dependent... So all that's to say, I don't know....!!! It just reads like I know a little!
Mike85mph
Sorry but you sig pic is way to large --
