Old 11-20-2004, 11:56 PM   #1 (permalink)
Is the zo6 titanium exaust actually better?
I have a 99 frc and was wondering if anyone has put the zo6 exaust on the car, and if so, how do you like it? I currently have Borla stingers and was wanting to know the difference, if any, in performance or sound.
FRCLandon is offline   Reply With Quote
Old 11-21-2004, 05:52 AM   #2 (permalink)
Cave Man's Avatar
Send a message via MSN to Cave Man
The Z06 exhaust probably won't give you any performance advantage over the Stingers. But it will be lighter and more corrosion resistant.
Marcus Aurelius
Cave Man is offline   Reply With Quote
Old 11-21-2004, 02:11 PM   #3 (permalink)
Corrosion resistant, like Cave Man said. There is a difference in sound: it would be quieter than the Borlas. I think the stock Ti system can flow 99% of what aftermarket flows.
Old 11-21-2004, 06:19 PM   #4 (permalink)
Well I appreciate the information....I bought the car with that exaust and was kinda attracted to the zo6 ti's. Ill keep the Borla though....since its no hp difference. Thanks fellas!
Old 11-21-2004, 06:21 PM   #5 (permalink)
Is the Factory Titanium system any good !
This is a reprint of a post that Tony from AFR heads made considering the effectiveness of the factory Titanium System
Z06 Ti Exhaust Info & Dyno Results
Hello Everyone,
I've been extremely busy or I would have already posted this information, but I have your back to back results on how good (or bad) a factory Ti exhaust system actually is. I have spent the last month or so fabricating a custom exhaust with "Y" pipes and electric cut-outs that when open allows the exhaust gas to "by pass" the muffler and go straight out the tailpipe exits. In reality, some of the exhaust gas will still go thru the muffler as well, but it will take the path of least resistance and the bulk of the flow will take the path off the "Y" pipe that exits directly to the rear. A picture is worth 1000 words, but I hope you get the "gist" of what I built. Bottom line, when the electric cutout is closed, all gases are routed thru the muffler and its business as usual, when I open the cut-out electronically, it essentially completely eliminates the muffler as a "restriction" in the system, not to mention sounds awesome at WOT.
First off, after I cut off both exits and inlet from the factory muffler, I was shocked to see that a 2.5" inlet pipe necks down immediate to a 2" pipe (1.875" ID) YIKES!!! I'm thinking sure it sounds "stealthy" at idle and cruise RPM's, but I would have bet you anything I was going to be down 10 plus RWHP minimum on a car putting down 475 or so at the tire. Good thing I didn't have anyone taking me up on that wager....the results were surprising to say the least.
First off, my last trip to the dyno netted me 477 HP....not quite the 480 I have seen on one or two of my previous best pulls, but right in line with the better of my "average" runs. This was achieved thru LG long tubes and the 3" metal matrix Cats and X-pipe. My former "cat-back" was a Magnaflow system that came with 2.5" pipes that go up and over the rear driveline. By the way, the weight difference between the two is exactly 25 lbs total....not too shabby a savings for guys trying to put their car on a diet.
On to the results....After spending a little time with LS1 edit adjusting the fuel curve (THANKS CHARLIE!), with my cut-outs in the open position, our two best power runs were 481 and 480 back to back with peak torque output on both of them peaking at 439 ft/lbs (huge # for stock displacement). We then proceeded to let the car cool for 10-15 minutes and with no other changes except for closing the cut-outs, running thru the "corked up" factory TI system, the car still put down two back to back runs of 476 HP and 475 HP, with peak torque output at 435 and 432 respectively!! I was shocked to say the least. Obviously necking down to a mere 2" pipe that far back in the system is less of a problem than MANY people would have ever thought. Looks like the GM engineers certainly did their homework....in a car with 100 less HP to the tires, I bet that system would barely cost you 3 HP....Very impressive indeed.
For you guys looking for the ultimate in "stealth" with your current headers/heads/cam cars....you can't beat the factory Ti system, BUT some of you might find it TOO conservative. I like the fact that with my new exhaust configuration you can "have your cake and eat it too" by having the best of both worlds depending on the mood your in.
Anyway....interesting info for all to read!!
Regards,
Tony Mamo
Old 11-22-2004, 09:51 PM   #6 (permalink)
That is some valuable info.....Thanks
Old 11-23-2004, 08:18 PM   #7 (permalink)
Send a message via MSN to DaTruth
Interesting.. I was thinking of going with the Z06 Ti.. My Borla's are pretty loud at WOT and with my current engine the car is never quiet. As for power... There is very little difference between opening the cutout and the borlas.. When I am getting on it my car sounds like it should be at Sebring..
1999 Chevy Corvette FRC
408ci Futral Motorsports Stroker
FMS/Meaux 6.0L Stage III heads 11.75 to 1
FMS 250/257 lsa 112.8 Hydr Roller Cam
2 Stages of dry nitrous on standby
555RWHP/520RWTQ NA
805RWHP/740RWTQ on the spray!!
DaTruth is offline   Reply With Quote
WTB: ZO6 Titanium Exhaust themindfield Member Sales - Parts & Cars 4 03-31-2006 08:29 AM
WTB: stock ZO6 titanium exhaust... georges03zo6 Member Sales - Parts & Cars 3 06-10-2005 10:23 AM
WTB c5 zo6 titanium cat back more carbon Member Sales - Parts & Cars 0 01-02-2005 01:14 PM
2002 ZO6 Titanium Exhaust RJGarcia Member Sales - Parts & Cars 6 06-17-2003 09:26 AM
2002 ZO6 Corvette Titanium Exhaust System IMBLISS Member Sales - Parts & Cars 5 07-16-2002 10:45 AM
