Go Back   Z06Vette.com - Corvette Z06 Forum > Z06Vette News & Polls > Z06Vette News
Old 08-27-2008, 02:21 PM   #1 (permalink)
Secrets Of The 2009 Corvette ZR1: Michelin Pilot Sport PS2 Tires
One of the most impressive things about the 2009 Corvette ZR1 is how much grip it has. Normally, sticking 638 HP into something that weighs just 3,350 LBS and driving only the rear wheels would result in massive amounts of wheel spin, both in a straight line and around corners. But in the ZR1, it doesn’t — not without significant provocation. This is partly due to the whiz-bang magnetic damping system that adjusts itself near-instantaneously to keep the car level around corners and keep the tires in contact with the road over rough surfaces. But a big part of its grip, and the resulting 7:26.4 ‘Ring time, comes down to the tires: Michelin Pilot Sport PS2 ZPs specially developed, racecar-style, alongside the ZR1.
Specific to the ZR1, the 285/30-19 front and 335/25-20 rear tires use a different compound from that of the normal PS2s (which can also be found on the 2009 Cadillac CTS-V), designed to deliver ultimate track performance while retaining the ability to last for 20,000 miles of road use. We’re guessing burnouts may reduce their life expectancy substantially.
Unlike earlier versions of run-flat technology, which we weren’t big fans of thanks to increased unsprung weight and a harsher ride, these latest Pilot Sports’ reinforced sidewalls actually contribute to handling while inflated, helping to transfer braking and cornering loads in a more direct fashion.
Additionally, the tires make use of a two-part tread design with large, stable blocks on the outside for maximum grip (the ZR1 can pull 1.05 Gs on the skidpad) and a more grooved tread in the middle for better water dispersion and lower tire noise. The sections are joined by a special “lightning bolt” decoupling channel, which allows each section to movie slightly, independently of the other.
We drove the ZR1 on both the road and track — in dry conditions only — and never found the tires to be lacking. On the track, they deliver considerably more grip than expected, while on the road they ride surprisingly compliantly, at least for such a big tire. Michelin hasn’t finalized prices for the PS2 ZP yet, but expect replacements to cost “$300 to $400 a corner.”
Source: Michelin via Jalopnik
Gallery: ZR1 Pilot Sport PS2
Old 08-27-2008, 06:32 PM   #2 (permalink)
Re: Secrets Of The 2009 Corvette ZR1: Michelin Pilot Sport PS2 Tires
If GM really wants to start "looking" competitive, they need to quit putting pseudo performance tires on the performance models. How many comparison reviews do we need to read where the Z06 was penalized by the tires?
I'll be curious to see how these ZPs compare to the normal PS2s.
Old 08-28-2008, 01:59 PM   #3 (permalink)
YumaZ06's Avatar
Duh, you think? I wonder how they came up with that conclusion?
2004 MS/BLK
NCM#31853
Old 09-20-2008, 09:51 PM   #4 (permalink)
Per Discount tire on 09/17/08
Had a little time while putting new fronts on the Z so I priced em.
Fronts = 575 each
Rears = 622 each
Total = 2394 + tx to put new paws on the ZR1
Doc E.
Dr.Electron is offline   Reply With Quote
Old 09-20-2008, 11:37 PM   #5 (permalink)
That seemed pretty cheap to me too! I just bought ps2's for my rears and the 345's cost me 490 each!
Old 09-21-2008, 04:42 PM   #6 (permalink)
Yeah, they're not too bright over there.
Old 09-27-2008, 08:48 AM   #7 (permalink)
65hemi's Avatar
Re: "We're expecting Burnouts may reduce their life expectancy substantially" - Really? Amazing. I thought doing burnouts would make your tires last longer as because of the extraneous tempering effect resulting from the extreme heat cycling.
Nothing quite like stating the obvious to make an article really interesting..................
65hemi is offline   Reply With Quote
Old 09-27-2008, 11:31 AM   #8 (permalink)
blkZ06's Avatar
I have PS2's on my Viper, they were $500/tire (335's in the back)
Old 09-27-2008, 11:37 AM   #9 (permalink)
MikesZ06's Avatar
Just order PS2's for my C6Z last week. Around $1600 for the 345 rears and 275 fronts. (rears are backordered)
9.87 at 141mph
& 2007 Black C6 Z06
Old 09-27-2008, 05:00 PM   #10 (permalink)
On the burn out statement, I think they infer that the ZR1 PS2's will wear faster than a normal tire concerning burnouts; due to softer compunds. At least that's the impression I got. I will take one for sure, if I could ever get the scratch together, lol.
Robert
'02 Z06 408ci, Multi Stage Direct Port Dry, 644rwhp and 717rwtq
Robert56 is offline   Reply With Quote
Old 10-10-2008, 11:37 AM   #11 (permalink)
Dynamic 'Lightening Bolt' tires, and dynamic shocks are here! Whats next?
The transmission! Paddle shifters: Ferrari's getting 40milli-second shifts compared to .25 or so. It exists and is a no-brainer, and is good enough for F1's!
rosulekg is offline   Reply With Quote
Old 11-19-2008, 07:16 AM   #12 (permalink)
Banned
SPAM
David Lee is offline   Reply With Quote
Old 11-19-2008, 11:10 AM   #13 (permalink)
Fronts = 575 each
Rears = 622 each
Doc E.
***edited***
Sorry, TireRack is no longer a site vendor here so links are not allowed
A little lower list price but then you have to pay for mounting. My calculations come up with:
Fronts = 520 each
Rears = 599 each
All four = 2338
Shipping = est $100
Install at est $35 per wheel = $140
So that's about $2,600 to put new paws on the ZR1.
Speed costs money, how fast do you want to go?
Dog
Old 11-24-2008, 04:29 AM   #14 (permalink)
awesome!
Br00nsie is offline   Reply With Quote
Rate This Thread:
HTML code is On
Michelin Pilot Sport PS2 tires jason31 C5 Z06 - Pit Road 5 02-23-2005 09:48 PM
Tires OEM V. Michelin Pilot Sport PS2 CCRider C5 Z06 - Pit Road 9 01-28-2005 07:32 AM
FS: Michelin Pilot Sport Cup Tires p51aviator Member Sales - Parts & Cars 2 09-24-2004 11:34 PM
Michelin Pilot Sport Tires for the Z06...... cholocholo41 C5 Z06 - Grandstand 29 12-01-2003 11:25 PM
F/S 2 Michelin Pilot Sport Tires 295/35/18 SuperZ Member Sales - Parts & Cars 6 04-20-2003 08:28 PM
