Go Back   Z06Vette.com - Corvette Z06 Forum > Z06Vette News & Polls > Z06Vette News > Z06Vette Polls
View Poll Results: Have you had the steering column lock issue?
Yes, column stayed locked after startup 68 15.18%
Yes, column locked while moving or after moving 14 3.13%
Yes, "Service Column Lock" Message only, wheel did not lock 42 9.38%
No 324 72.32%
Voters: 448. You may not vote on this poll
Old 09-07-2003, 04:59 PM   #1 (permalink)
Column Lock poll
Everytime I start up I get the "service column lock" on DIC but the column is not locked. I no longer hear the familiar sound (on shutdown or startup). Guess its off to the dealer, even though the car is manual I may still demand they remove or bypass the mechanism like the A4. Makes me nervous with all the horror stories I've heard. Car is 2003 with 2500 miles, about 4 months old.
So out of curiosity I want to see how many have had the issue and in what way.....
-Dave
MY 03 Z06 is offline   Reply With Quote
Old 09-07-2003, 05:11 PM   #2 (permalink)
Dave
Picked up my 03 in May. To date no DIC messages, no problems. Except of course the occasional brake squeal
03 EB Z is offline   Reply With Quote
Old 09-07-2003, 05:15 PM   #3 (permalink)
Originally posted by 03 EB Z
Dave
Got mine end of April, today was the first time I saw this message, and its not overly hot or cold here. I can check the fuse but if its blowing the fuse that tells me something is wrong.
Brake squeal here too, has gotten worse, I can deal with that, if it annoys me I'll go to harder pads.
Exhaust jingle too, I can deal with that, and if I get annoyed I'll make the dealer buy me an X pipe.
Steering wheel locking/car stalling at xx MPH, that I can't deal with, not even the possibility.
I just don't like letting the dealer tinker with my car I may just tell them to give me the A4 bypass (I'm not paying $100 to fix their problem) and doing it myself.
-Dave
Old 09-07-2003, 05:18 PM   #4 (permalink)
To clarify, option #2 means the lock engaged after you started the car but before you shut it off (engaged when it wasn't supposed to).
-Dave
Old 09-07-2003, 08:24 PM   #5 (permalink)
No column lock here!
Sig by the Hillbilly!
Old 09-07-2003, 10:44 PM   #6 (permalink)
So good so far, No column lock here!
Old 09-08-2003, 12:05 AM   #7 (permalink)
I have an 02 with 15k on the odometer. I have gotten the service column lock message and a message to remove the key for ten seconds.
No lock up yet. But I am going to tell the tech. when I take it in for an oil change.
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Old 09-08-2003, 12:16 AM   #8 (permalink)
Send a message via MSN to mwascom Send a message via Yahoo to mwascom
2002 with 10K miles; no issues yet. Knock on wood !
Sig by Z06nut
mwascom is offline   Reply With Quote
Old 09-08-2003, 04:37 AM   #9 (permalink)
While common on the first few years of the C5, this should not be an issue on your car. I would have it looked at.
Old 09-08-2003, 05:14 AM   #10 (permalink)
3 years of ownership and no column lock issue.
Old 09-08-2003, 06:01 AM   #11 (permalink)
Super Moderator
Black_Magic's Avatar
Dave,
I had both situations happen. I had what you now have message but CL stuck in open position for about 9 months. Took to dealer for recall (fix) Dec 2001 and then at the Fest last year it LOCKED in front of the Hampton Inn Got unstuck by wiggling Steering wheel, Disconnecting battery (thanks Zippy) and everything ok.
BTW I just installed CLB last week because I didn't want the problem again (~$40).
You can DEMAND but it would be against the LAW for a dealer to disconnect/remove like A4's because a anti-theft feature is required and the A4 has transmission lock also.
George
Click Here for Black_Magic Home Page
'99 Blk/Blk Vert, 6sp, Magnason S/C, Corsa Indy Pro Tips, M12 Trans, Z06 CAM, FLP Headers, HRE 547's SOLD May/2008
'65 Blue/Blue ZZ4-Dual Quads, TKO 5sp, PS, PB A/C, Tilt, Sidepipes, Torque Thrust II (17*7) (DRIVER)
Black_Magic is offline   Reply With Quote
Old 09-08-2003, 06:30 AM   #12 (permalink)
I've had my '02 for about (5) months and have had the column lock problem about (10) times. Only once did the column lock remain on after removing the key and waiting (10) seconds.
The other nine I had to do the Jerk and turn maneuver.
Soon as I get back from the Z06Fest and Fun Fest at MidAmerica it's back to the dealer for a fix (???).
Steve
T-Rex Cam (242/248, 608/612, 110), Comp921 springs, Kooks 1 7/8" Hdrs, x-pipe/off-road pipe,Vararam, 4-tip Stingers, ASP UD Pulley, Dual Row Timing chain,TR55IX plugs, MSD Wires, Raptor shift light, 4-point roll bar, Nitto 555R2, 451 rwhp/396 tq NCM Member #23233
smithsc is offline   Reply With Quote
Old 09-08-2003, 11:33 AM   #13 (permalink)
George
I know its (stupidly) illegal, but something that could potentially put my life in danger is a much bigger legal risk for them I would think.
-Dave
Old 09-08-2003, 11:41 AM   #14 (permalink)
My car is over a year old and NO problems.
If I get that message it goes rite in for service.... that column lock problem makes me nervous
Rick
Vortex Rammer/Predator Tune/Painted Fuel Rail Covers (EB)/TB Bypass/160° Stat/Borla 2Tip Stingers/Performance Hood Seal/APC Bulbs/Hurst Shifter/MGW Gripper Knob/Bazooka Tube/Shorty Antenna/Lowered/Zaino
ZEE06RICK is offline   Reply With Quote
Old 09-09-2003, 03:40 AM   #15 (permalink)
CHS20030001 Request for Customer Complaint Vehicle That Has Allegedly Experienced Steering Column Lock Mechanism Engagement During Vehicle Operation - actuator connector diagnosis DCS inoperative #PI01137 - (06/04/2003)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
From DCS CHS20030001
URGENT - DISTRIBUTE IMMEDIATELY
DATE: January 13,2003
SUBJECT: Request for customer complaint vehicle that has allegedly experienced steering column lock mechanism engagement during vehicle operation.
MODELS: 1997-2003 Chevrolet Corvette
TO: All Chevrolet Dealers
ATTN: Service Manager and Service Advisor
GM Service and Parts Operations is requesting your assistance. We are looking for any 1997-2003 model year Chevrolet Corvette that allegedly has experienced steering column lock engagement during vehicle operation. If you have a customer complaint alleging that the steering column lock engaged during vehicle operation, please submit a Field Product Report (FPR) immediately. See Service Bulletin 02-00-89-002A for FPR instructions.
We are interested in knowing about any Corvette that has allegedly had this occur. It is VERY IMPORTANT that the vehicle not be disturbed once the condition is reported. DO NOT insert the key into the ignition lock cylinder. The ignition lock cylinder MUST remain in the 'Off' position. The vehicle should be transported via flat bed truck to the dealership and an FPR submitted. GM personnel may wish to visit your dealership to inspect the involved vehicle.
When submitting your FPR please make sure to provide your name, the dealership[rsquo ]s name, location and a telephone number where you can be contacted along with the Vehicle Identification Number (VIN) of the subject vehicle and a brief description of its condition.
You will be contacted within 24 hours to advise you how to proceed and of our intention to visit your dealership.
We greatly appreciate your assistance.
END OF MESSAGE
GM SERVICE AND PARTS OPERATIONS
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
Sent by an anonymous source.
Rate This Thread:
column lock again Dr.Bigg C5 Z06 - Grandstand 26 06-10-2006 11:06 AM
Column lock issue poll nucferr C5 Z06 - Pit Road 29 04-18-2006 09:13 AM
column lock help??? alzo6 C5 Z06 - Pit Road 1 07-13-2003 01:17 PM
Poll: Steering Column Lock? Zippy C5 Z06 - Grandstand 14 06-13-2001 09:37 PM
Column Lock Bypass Kit...prevent 'lock-up' on your Z06 RG Vendor Sales - C5 20 02-02-2001 08:05 AM
