Does your 08/09 tranny grind when cold? - Z06Vette.com - Corvette Z06 Forum
Go Back   Z06Vette.com - Corvette Z06 Forum > Z06Vette News & Polls > Z06Vette News > Z06Vette Polls
View Poll Results: Does your 08/09 transmission grind when cold?
Grinds when cold 26 66.67%
Shifts normal when cold 13 33.33%
Voters: 39. You may not vote on this poll
Old 11-26-2008, 08:38 AM   #1 (permalink)
There seems to be a problem with the first to second and second to third shifts when the transmission is cold.
It would be nice to see a show of hands of who has the problem. Hopefully, Gm will "bail us out" with an updated transmission or synchro set after they receive enough complaints.
Old 11-26-2008, 09:33 AM   #2 (permalink)
ZO6THIS's Avatar
Re: Does you 08/09 tranny grind when cold?
I posted this on the other thread about this to,
Ford is also having a problem with the tranny.
New Owner 07' Shelby GT500! But i think somethings wrong with it? - SVTPerformance
ZO6THIS is offline   Reply With Quote
Old 11-26-2008, 01:16 PM   #3 (permalink)
The T6060 didn't come out until 08 in the Z so I wonder if they're talking about the same problem.
Old 11-26-2008, 07:49 PM   #4 (permalink)
My hard 1-2 shift happens when hot, but no grind just won't go in. Only sometimes.
Old 11-27-2008, 04:36 PM   #5 (permalink)
They already have. Or at least they've bailed themselves out as there's a TSB (#2073364) regarding this...
"#PIP4357: Noise During The 1-2 Shift When Cold - keywords first grate grind second - (Feb 27, 2008)
Models: 2009 Cadillac CTS-V - Tremec Transmission RPO Code MG9
2008-2009 Chevrolet Corvette, Corvette Z06
Equipped With Tremec Manual Transmission RPO Code MM6, MZ6 or MH3
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment about a Nibble or grate type noise that may also be described as a multiple bump feel during 1-2 upshift event while the transmission is cold.
Recommendation/Instructions:
A new transmission synchronizer design was released for the 2008 and 2009 models listed above. The new synchronizer will make a noise when shifting from 1st to 2nd gear in temperatures at or below 32 degrees F.
This noise/feel is a normal characteristic and wil go away after the transmission warms up. Warm up should occur after approximately 15 miles of normal driving. This condition requires no repair by the dealer.
The service technician should test drive the vehcile to verify the concern. If the noise/feel goes away after the warm up no repair is necessary and the customer should be advised accordingly."
Old 11-28-2008, 10:28 PM   #6 (permalink)
My 09 is notchy when cold and smooth when it warms up.
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Old 01-01-2009, 06:54 PM   #7 (permalink)
My 08 does not go into 2nd smoothly when cold. The problem goes away after a short time. Less time that what I would think it takes to get any significant temp in the transmission. Much better than my 02 was though.
SOLD 2002 Z06 Millenium Yellow/black. All options except museum delivery & BSM
2008 Z06 2LZ Victory Red/Ebony
Terry S is offline   Reply With Quote
Old 03-10-2009, 05:39 AM   #8 (permalink)
Re: Does your 08/09 tranny grind when cold?
The transmission shifts very smooth once it's warm so being a little notchy when cold is not a big deal. Heck, it takes me about the same amount of time before I start shifting smoothly once I wake up in the morning.
The performance and feel of the car more than make up for this tiny quirk.
Old 03-10-2009, 06:40 AM   #9 (permalink)
Dragon's Avatar
Same here. When cold it feels like I don't have the clutch in far enough when I shift from 1st to 2nd and then from 2nd to third. After it warms up it shifts as smooth as butter in all gears.
"It's never too late to realize what's important in your life."
1965 Shelby Cobra - 2012 Cooper S - 2012 Grand Cherokee
Dragon is offline   Reply With Quote
Old 07-27-2009, 06:38 AM   #10 (permalink)
MSiska's Avatar
My 06 never ground. Must be the new improved TR6060!
Z06Fest Addict: I II III IV V VI VIII IX X XI
Old 12-18-2009, 09:35 AM   #11 (permalink)
Mine is experiencing the same problem. Not so much in 2nd, that shift is fairly clean, even cold. The 2-3 shift however makes the grate sound when cold. It sounds like a bad synchro, but does go away when warm.
The car also will sometimes chatter a bit on takeoff, but only about 10% of the time. Most times it's very smooth. I'm attributing it to the friction coefficient of the clutch as it's just grabbier than other clutches. If there was a problem with the flywheel, I would expect it all the time. Has anyone else experienced this feeling?
Z06~Acclaim is offline   Reply With Quote
Old 12-18-2009, 06:44 PM   #12 (permalink)
panzer's Avatar
JubJub you live in the south, in Georgia, everyone knows it never gets cold down there...
1985 BMW K100 m/c 2005 Custom Mustang 07 MB SL550
Old 12-21-2009, 03:50 PM   #13 (permalink)
I have a 08, it does not really GRIND, but I can really feel it, it is kinda like a "Harley" when you shift, if you try and ez it in, it will grind, but if you go ahead and kinda slap it into gear, no problem...BUT>>this is not a Harley, I did buy a used ZO6 that had 30,000 on it, so I was trying to be carfeul, until I really got the feel of it and even posted about a cluth? maybe starting problem, I still have not got a answer from any one if THEY think GM will replace clutch, IF, it is still under 36,000, "I bet not" but who knows?
Jim
jtbarnet is offline   Reply With Quote
Old 04-14-2010, 12:42 PM   #14 (permalink)
OK...chilly then.
Since I posted this I have long forgot about the tranny. I've gotten use to it and it's not really a problem. Definitely not worth having someone stick their dick beaters inside.
Old 12-26-2011, 09:39 AM   #15 (permalink)
MSiska's Avatar
What is a "dick beater"? :-?
Rate This Thread:
Head lamp grind? Blackened C5 Z06 - Pit Road 9 10-02-2006 10:44 AM
1st - 2nd gear grind Pbalias C5 Z06 - Pit Road 11 03-25-2005 02:30 PM
Cold Tranny and Shifting........ Launchn C5 Z06 - Grandstand 14 12-04-2003 09:51 AM
3rd Gear Grind Tom Fuscaldo C5 Z06 - Grandstand 7 06-03-2002 03:44 PM
Grind in 4th gear ReddyZ06 C5 Z06 - Grandstand 2 03-15-2002 04:32 PM
» Insurance
» Latest Auto News
Mazda to Debut New Model on Xbox Live
Mazda has teamed up with Xbox to produce the first-ever global live
2014 Aston Martin Vanquish Volante is Dripping With Sex Appeal
Aston Martin has just unveiled its 2014 Vanquish Volante, the first
Five-Point Inspection: 2013 Fiat 500e
As fuel prices continue to test the limits of infinity, small cars are
» New Car Reviews
2013 Honda CR-Z Review
Not hot enough and not eco-enough
2014 Mercedes-Benz E350 Wagon Review
Wagons East: This Benz is Sweeter than Candy
2013 Audi RS5 Review - Video
The last of a breed and the best of the bunch
2014 Chevrolet Impala 2.5L 4-Cyl Review
Are four cylinders two too few for Chevy's new sedan?
2014 Kia Rondo Review
You can't buy it, but do you even want to?
» Featured Product
