DIY - Front Upper Control Arm Removal and Installation
I recently replaced all of the OEM control arm bushings on my 2003 Z06 with the VB and P polyurethane bushings. I thought that I would post a write-up for those of you who might be interested in this modification. NOTE: the bushing removal and installation instructions are in a separate post in the Pit Road forum.
I started with the obvious, chocking the rear tires and jacking the front of the car. I placed my flat-top AC Hydraulics jackstands under the front jacking pucks in order that the jackstands would not be in the way. The car is very stable in this position.
1. I removed the wheel and tire assembly and supported the lower control arm on a jackstand.
2. With an 18mm open end wrench and a 5mm Allen wrench in the ball joint stud I loosened the ball joint nut.
3. Using the Kent-Moore J42188 joint separator I separated the joint. This tool is not absolutely necessary but is worth its weight in gold. I then discarded the nut as these are single use nuts. DO NOT REUSE THEM.
4. I removed the 15mm bolts attaching the control arm to the frame, taking note of any shims behind the bolts so as to replace them in the right places. I then removed the control arm to replace the bushings in the shop.
5. I reinstalled the 4 control arm bolts with the shims in the proper places, torqueing them to 48 ft. lbs. I made sure that there was no fore-aft play in the bushings prior the tightening the bolts to 48 ft. lbs.
6. I reinstalled the ball joint to the control arm and tightened to 15 ft lbs, using an 18mm crow foot and the 5mm Allen wrench to prevent the stud from spinning. I used my Snap-on Techangle torque wrench and tightened the NEW crush nut, PN 03537772, 250 degrees to the minimum torque of 41 ft lbs. You could probably just estimate the angle and be okay. The Techangle is a cool tool and allowed me to do the job by the book.
That's it , the front upper control arm is done. Note that I DID NOT remove the caliper and rotor as it is just not necessary. I don't believe this took more than about 45 minutes and was not difficult.
