Old 11-11-2007, 02:45 PM   #1 (permalink)
DIY - Lift your C5 without pucks
How to safely and quickly lift your C5 without using jacking pucks
By Mark Vaquer
If you’re like me, having to go through the process of using ‘jacking pucks’ can be a pain in the butt. This is something that I dreaded doing even before I acquired my Z06. Lifting your car in order to change your oil or remove your wheels shouldn’t take hours. By using this alternate method of lifting your C5, you can lift your car as needed, with simple garage tools in under 20 minutes! Many modifications & routine maintinance can be performed using this lifting method. There will certainly be instances where you will have to resort to the tried & true ‘jacking puck’ method, but for many lifting requirements, this much quicker ‘alternate method’ will work just fine with a minimum of time & effort.
To lift your C5 using this alternate method, you will need the following:
  • An adequate heavy duty floor jack (2-3 ton minimum; this method doesn’t require an expensive ‘low profile’ floorjack)
  • 4 - 3 or 4 ton capacity quality ‘4 point’ base jackstands
  • 2 pieces 2 X 6 X 25 inches wood or very hard, dense plastic
  • 4 pieces 2 X 12 X 16 inches wood or very hard, dense plastic (Treated exterior wood works best)
Begin by setting a single 2 X 12 X 16” piece of wood in front of each tire, front & rear. Do not set the wood right against the tire; set it about 4 or 5 inches in front. Make sure that these pieces of wood will not slide when you begin to drive the car up & on them. The best possible way for this is to have the car on a large piece of carpet. This is the way I do it & I’ve never had a problem with these pieces of wood moving or slipping when driving the car onto them.
Get in the car. Slowly drive the car up & onto the blocks. You will need to give your car a small ‘running start’ to get on the blocks. If you hit them & the car doesn’t go up on them DO NOT try to force it! If you do this, you will ‘flip’ the rear wood blocks up with enough force to hit & possibly crack the fiberglass underneath. Let the car back up and drive just a touch faster until the car is on the blocks. This may take a couple of times (similar to the ‘rocking technique’) but the car will easily go up & onto these blocks. Once the car is on the blocks, & before going any further BE POSITIVE THAT THE EMERGENCY BRAKE IS ENGAGED & THE CAR IS IN GEAR (or in ‘park’ for automatic C5’s). Also, if you’re going to be removing one or all of your wheels, be sure to break the lugnuts loose before lifting the car. Here is a picture of what your car should look like when it’s up & on the blocks.
Once the car is safely on the wood blocks, take your floorjack to the front of the car & center a piece of 2 X 6 X 25” wood on the lift.
Move this combination under the front end. You will see that the lower air dam will touch the piece of wood
Reach under and pivot the lower air dam out of the way just enough to move the floorjack with the wood past it. Once past the air dam, position the jack/wood under the front aluminum cross member taking care to not let anything touch the fiberglass leaf spring. Raise the floorjack until the wood makes contact with the cross member. At this point, look and check that the wood and floorjack metal lift pad are centered under the cross member. When they are, lift the car to the desired height. Be very careful to not hit the front fascia with the floorjack handle while raising the car.
After you’ve lifted the car to the required height, move the 2 jackstands into place under each side of the wood being sure to leave enough space in the middle to allow you to remove the floorjack from under the car. When you lower the car onto the jackstands be sure not to let the car down too fast & hard! If you do this, the wood could possibly split! Let the car down slowly & gently onto the wood. Lower the floorjack & remove from the front of the car.
Move the floorjack around to the rear of the car & repeat the same procedure as above. Move the floorjack with the 2 X 6 X 16” wood under the rear cross member, again taking great care to not let anything touch the rear fiberglass leaf spring.
Once you’ve centered the floorjack/wood under the rear aluminum cross member, raise the rear of the car to the desired height.
Again, move two jackstands into place on each side of the wood. Lower the car gently onto the jackstands. Now you can either remove the floorjack or leave it in place to add some extra safety
This is a front to back picture of the rear of the car fully lifted with the floorjack left in place for added safety. Note that nothing is close to the fiberglass leaf spring.
Now the car should be fully lifted off of the ground. There is no metal touching the aluminum cross members, only wood. The car will be very sturdy lifted in this manner and can be left like this for days if needed. This entire operation should take less than 20 minutes from start to finish. Initially it will probably take longer, but once you’re used to it, you’ll be surprised at just how little time it takes to completely lift the car. You can actually change your oil & filter in less than an hour lifting the car in this manner. You can also lift just the front or just the rear using this method. One thing to be aware of; if you’re going to lift the rear only, you still need to drive the car onto all 4 woodblocks. If you don’t, you can lift the rear high enough to where the front fascia will actually touch the ground! I’ve been lifting my car using this method for over a year with great results & no damage. I don’t even own a set of ‘jacking pucks’; I still haven’t had a situation arise where I need to purchase or make a set!!
Disclaimer: You perform this operation at your own risk. I make no claim that the information contained in this article is accurate, complete or that it will not damage you and/or your automobile. The information contained herein is strictly for educational purposes, intended for Z06Vette.com/CFiveVette.com forum members & is only from my personal experiences. Remember to use common sense when lifting any car and crawling beneath it. Always make sure that it’s properly and securely supported with the proper equipment and always on level ground, preferaby on a concrete surface, and NEVER on dirt or grass!
Old 11-13-2007, 07:46 AM   #2 (permalink)
Re: DIY - Lift your C5 without pucks
Thanks for the information on lifting the ZO6 that I just purchased last month. I always cleaned the undercarriage when I went to the car shows,but this car is readly low to the ground. This looks like a very save method.
BobSk is offline   Reply With Quote
Old 11-14-2007, 10:26 PM   #3 (permalink)
F.J.B.'s Avatar
x
Vette Doctors Performance RX450 package.
466 RWHP!!!!!!!!!!!(DOA 8/17/09 @ approx 1100 hours.)
RX550 Completed!!!!
Final numbers to be announced at a later date!!!
F.J.B. is offline   Reply With Quote
Old 11-15-2007, 08:38 AM   #4 (permalink)
DennyM's Avatar
Congratulations on the Z and welcome to
How 'bout posting up in the appropriate Grandstand sub-forum and tell us about your ride? :idea:
Enjoy!
Old 11-17-2007, 04:28 AM   #5 (permalink)
Eddie 70's Avatar
Nice little article. I have been wondering how I was going to get mine up on the ramps to change the oil. Now I have the perfect way to get there. Good work.
02 EB Z06 No Mods Yet
12125 miles on 11/10/07
56621 miles on 3/3/10
Old 05-03-2008, 06:46 AM   #6 (permalink)
Because I frequently change tires for the track, I designed permanent lifting pucks. If you want to see, I can email a picture. larrybitt@charter.net
Larry Bittner is offline   Reply With Quote
Old 07-19-2008, 08:08 PM   #7 (permalink)
just bought my first 02 z last october, amazing. as far as lifting it i took some 2x 12's, cause i run 345's and slammed on stock bolts, cut 20 degree angles on the front edge and put another 2x12, with same angle 14" back- so they are stacked and a total of 30" long. line all 4 behind the tires, if your slammed you know what its like in the front, rock the car slightly and she'll ride up 1 stage, becareful and go up another stage. plenty of jack room. cost 20 bucks versus custom ramps and lo pro jack. you can get a jack anywhere under this car and not hurt the rockers
banditz06 is offline   Reply With Quote
Old 08-01-2009, 07:52 AM   #8 (permalink)
This is a great post! I just bought a Z and I've been wondering what the best way will be to get it jacked up for servicing. I might lower it some day in the future too, so this post is full of good info.
Thanks dascrow!
Highpsi is offline   Reply With Quote
Old 08-01-2009, 12:25 PM   #9 (permalink)
RocketSled's Avatar
I'm not sure I understand why jacking with pucks takes you hours. The process you describe, in fact, looks like it takes quite a bit longer to do than the process I use. My process:
1) I reach under the car and insert/turn/lock the jacking puck - 5 seconds
2) Slide jack under puck - 10 seconds
3) Jack car - 30 seconds
Since the chassis is quite stiff, you only need to lift at one point on one side to get the entire side off the ground. Very "F1-ish", in fact. I typically jack and the front since that end of the car is heavier. Once the front wheel is more than about 4" off the ground, the rear wheel comes up as well. With my floor jack fully extended, I have about 12" or more under each wheel on the side being lifted.
Sure, if it's been lowered at all (my C5 is at the bottom of the stock bolt travel), a standard floor jack won't get under the car, pucks or no pucks. But "low profile" floor jacks do the trick nicely and (at least the one I bought at local car parts store) aren't any more expensive than a standard jack. Mine even has a nice rubber "jack pad" rather than the steel cup so common on a normal floor jack. My low profile jack gets under the car even with a puck (clearing by mere fractions of an inch, but clearing just the same).
C6!
Old 08-03-2009, 09:16 AM   #10 (permalink)
froggy47's Avatar
I bought 2 craftsman low floor jacks for about 100 each so I can do l/r front or l/r rear (for swaybar/shock/brake work).
That takes maybe an additional minute for the other side.
Safe, fast, ez. Toss some jack stands under for safety.
When I do wheel changes street/track I also jack the side of the car up with one jack (BMW works the same way).
Not that the op has a bad idea, but speed wise it's faster with low floor jacks.
2007 BMW 328i Coupe, 2004 Z06/Z16, 1996 LT4 Coupe, 1995 BMW M3 Coupe, Ford & Chevy SUV's
2006 & 2009 SCCA regional Solo champ AS & SS
Rate This Thread:
Jacking Pucks FYI RalphP C5 Z06 - Pit Road 8 08-19-2007 07:05 AM
Jacking Pucks? Vrrooom C5 Z06 - Pit Road 6 09-21-2004 08:58 AM
Jacking up the car... do I need pucks? MacMan C5 Z06 - Pit Road 21 07-18-2003 07:42 AM
BMW M3 Jacking Pucks MXRACER C5 Z06 - Pit Road 7 10-16-2002 07:52 AM
Pucks.. BrianK C5 Z06 - Pit Road 2 11-14-2001 05:10 PM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
