Old 11-11-2007, 02:44 PM   #1 (permalink)
DIY - Lowering your C5
Front:
Lowering a C5 is very simple especially if you have access to a lift. I had my Vette mechanic (Vettemaster) lower Sherylann's Z06.
You need to ease the tension on the front spring by using a jack.
Use a 10 mm socket and turn the bolt fully counterclockwise, then back off 1/4 turn.
Rear:
Locate rear adjusting bolt. Use a 13/16" wrench on the top nut and a 18 mm wrench on the bottom.
Top view:
Bottom view:
Turn lower bolt until 2 threads remain showing on the top.
That's it...its best if you have your alignment checked after about 1 week of driving. Be sure to take a banner picture of the mechanic!!
Disclaimer: Neither the author nor the *Vette family of sites claim any fitness or warranty on the above diy tips. Any injury or damage incurred as a result of the use of the tips is the resposibility of the user.
Old 05-04-2008, 06:05 AM   #2 (permalink)
Re: DIY - Lowering your C5
please post up "After" pics of the lower"ness", lol
s15driftking is offline   Reply With Quote
Old 05-04-2008, 09:20 AM   #3 (permalink)
PerforminNorman's Avatar
Here's my 01 with stock bolts and cut bushings.
Old 07-19-2008, 08:12 PM   #4 (permalink)
just want to note if the car is slightly older and stock some adjusting bolts may be stuck. easiest solution was to take the leaf out, very easy on jack stands, i welded a nut on the stock bolt- no problem spun right out. now she is slammed on stock z06 gear and rides pretty decent, for new england roads i guess! just want to add i took out the stock bolt altogether and made my own rubber pad out convetor belt material, the spring will rub on the control arm if you don't protect it, and used my own blend of epoxy resin to hold it in place. its very quiet and looks great with 265/35-18 in the front
banditz06 is offline   Reply With Quote
Old 04-07-2009, 06:40 AM   #5 (permalink)
i just did this mod and drove it for about 10 miles and it doesnt look any different, how long does it take to settle?
02Z06QS is offline   Reply With Quote
Old 04-07-2009, 07:03 AM   #6 (permalink)
DennyM's Avatar
Welcome to and thank you for your service to our country
Did you lower as much as stock bolts would allow? (you have the front snubber tightened against the leaf on the bottom and max threads showing on top?)
In the rear you have dropped an equal amount (gives' you about one finger difference in height and keeps rake the same as before)
It should settle to lowered height in 50 miles or so.
Then get the alignment checked and reset.
Old 04-07-2009, 07:51 AM   #7 (permalink)
Your welcome, Im glad to be here and finally own a Z06. i did exactly what the directions said to do. i left 2 threads in the back showing (equal on both sides) and did 1 full counterclockwise turn then backed off a quarter turn. i think it is settling a little bit more. i have never had to do something like this before. I just came from a Honda S2000 and had a full coilover suspension on there so i guess i just expected more right off the bat. But i will be happy if it sits like the red one in the pic above does. Next mod exhaust. Thanks for such a quick response.
Old 04-26-2009, 03:55 AM   #8 (permalink)
so did the car settle down?
2004 Z06 Corvette. Borla Stinger Exhaust, Vararam RAI, B&M Ripper shift kit, Cags eliminator, ZIP lowering kit, slotted and drilled rotors RWHP???
STi-to-Z06 is offline   Reply With Quote
Old 04-26-2009, 07:17 AM   #9 (permalink)
Not really,if it did then it was very little. The thing still looks like a monster truck. I can fit about 3 1/2 fingers in the gap on the front and rear. its driving me nuts.
Old 04-26-2009, 01:24 PM   #10 (permalink)
chewbakkah's Avatar
you could always do some coilovers
still waiting on the z06 to materalize in my driveway. shouldn't be long now.
chewbakkah is offline   Reply With Quote
Old 04-26-2009, 04:23 PM   #11 (permalink)
Im not going to track the car, i just want to make it look pretty. I will eventually attemp to cut the bushings and if that doesnt work get longer bolts. I just need to find out what kind to get. If the red car above did it like that i dont understand how mine is sitting so much higher.
Old 04-26-2009, 05:03 PM   #12 (permalink)
DennyM's Avatar
Mine dropped about a finger - normal sized hand - got 4 fingers between tire and fender before; 3 after.
If you want to go lower, instead of cutting your bushings, you might look at the kit that either Vette Brakes & Products or ZIP products sells ... few bux and quicker ... :idea:
They also sell a bump steer kit. (necessary when you drop past the stock range of adjustment, IMHO)
Old 04-27-2009, 04:53 AM   #13 (permalink)
Yeah i will check those out. Thanks i appreciate that.
Old 04-28-2009, 04:35 AM   #14 (permalink)
I have the ZIP kit. It has not been installed ever. I plan to try lowering on the stock bolts, if I am not happy I will use the zip kit, if I am happy i would gladly sell it to you for a good price.
Old 04-29-2009, 10:23 AM   #15 (permalink)
Cool that works, just let me know.
Rate This Thread:
lowering Z06 Levendi C5 Z06 - Pit Road 28 11-29-2004 03:03 PM
Lowering My 01 Matt Cannavino C5 Z06 - Pit Road 6 04-04-2003 01:48 PM
lowering Z06 vipereater C5 Z06 - Grandstand 12 07-14-2002 03:14 PM
Help on lowering Z06-> delta C5 Z06 - Pit Road 2 07-05-2002 03:31 PM
Lowering Help ! ElectronZ06 C5 Z06 - Pit Road 8 07-02-2002 10:04 PM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
