Old 04-22-2004, 09:57 PM   #46 (permalink)
Jub, you sure that it isn't the end off your bathroom plunger? I can still remember the pics your wife took when you got your laptop.
04 Z06 MY/ModRed(SOLD)
04 Z06 Z16(SOLD)
Old 04-23-2004, 06:07 AM   #47 (permalink)
So that's where my plunger went!
Old 04-25-2004, 10:41 PM   #48 (permalink)
I have an installed (not by me) Hurst shifter and would like to do this mod. How do I pull up the leather boot to expose the boot underneath to install the rubber cap? Thanks!
Topgun is offline   Reply With Quote
Old 04-26-2004, 05:40 AM   #49 (permalink)
Remove the shift knob. If the shift knob is stock, pry off the plastic cap (with shift pattern) with a small screwdriver. Once the cap is removed, take two screwdrivers, and by prying against the the shift knob, lift out the retaining clip. Unscrew the knob. Once the knob is off squeeze the leather boot along the bottom where it goes through the console and that should be it!
Old 04-26-2004, 08:52 AM   #50 (permalink)
You know, I've tried the fix with the 2'' and with the 1 1/2" cap and I can't seem to get it right.
The 2" I put on with the flat part up and tried to get the factory boot to fit inside the cap......couldn't do it. Then I switched it around. With the flat side down and the open en up, it's just sitting there on top of everything. I drove with it like that for about 2 weeks. The noise has gone away almost completely but the vibration noise is still very apparent under medium to hard excelleration!
This weekend, I went and got the 1 1/2" version. When i took the thing apart again, there was a lot of frayed rubber down in the hole.....I guess from the cap and the stock boot rubbing together. Now, with the 1 1/2", I put it on with the flat side down and tried to fit it inside the stock boot opening. I could just about get it all in there but, when I ran through the gears(without even driving the car)the cap popped out. So, whew.....lol, I turned it upside down. With the open side of the cap down and the flat side up, I managed to fit it into the stock boot. I'm still haveing the same problem. The damn thing is working it's way out again.
Is there something wrong with me or am I not doing this thing the right way again? Please help!
04 Z06 Mil Yellow Mod/Red - Donaldson Blackwing, Power Duct, Velocity Stack, Throttle Body By-pass, Hood Seal, Hurst Short Throw Shifter/Billiard Ball Knob, Eckler's Z06 Partition, Random Technology High Flow Cats and X-Pipe, 170 Thermostat, LS1 Edit, DuraStop Ceramic Pads and Drilled/Slotted Rotors.
HDRAMROD is offline   Reply With Quote
Old 04-26-2004, 09:15 AM   #51 (permalink)
From what I understand, on the 03-04 models, there is a plastic ring inside the boot and this needs to be cut out. I guess the rubber on plastic doesn't grip well enough and you wind up with what you've described. Can you check to see if that is the case and if so maybe you can cut it out and then reinsert the plug. I've had mine in for over a year and it's still in there!
I had another thought, you might be able to use the 2" pipe plug on the outside and use a hose clam or something similar to ensure a firm grip of the plug to the boot. Since the plastic ring is inside you should be able to tighten well enough to keep it from slipping off. Also, it might be a good idea to apply some silicon or vaseline grease to the plug where the shifter shaft goes through.
Old 04-26-2004, 09:38 AM   #52 (permalink)
Jub,
I was thinking of gluing the rubber boot to your plumbing mod to negate the slipping (I did have to cut out that plastic ring).
My Hurst is still noisier but only at WOT and the feel makes up for it (between the exhaust, the tires, and the Hurst, I can see her lips moving but I can't hear a thing she is saying). Life is good.
DarkHelmet is offline   Reply With Quote
Old 04-26-2004, 09:45 AM   #53 (permalink)
Originally Posted by DarkHelmet
Jub,
My Hurst is still noisier but only at WOT and the feel makes up for it (between the exhaust, the tires, and the Hurst, I can see her lips moving but I can't here a thing she is saying). Life is good.
A good rubber cement should do the trick. BTW, I also reinstalled my Borlas because there was too much and not enough engine sound. Life is good!
Old 07-01-2004, 05:09 AM   #54 (permalink)
Send a message via AIM to outlw Send a message via Yahoo to outlw
I'll try the tape first... since it is quicker to do. then if not I'll try this mod... :-)
Z06 PARTS FOR SALE... Brand new stock plug wires,Ported throttle body, Lyodd Mats front and rear, Kirbin Shifter, Hurst Shifter, rear cargo net, New Car Cover,
outlw is offline   Reply With Quote
Old 09-29-2004, 07:40 PM   #55 (permalink)
One thing you have to remember with this mod is that the plug mostly quiets the sound from the torque tube and it dampens the rattle from the hurst shift shaft. To what degree it quiets the rattle depends primarily upon how well your flywheel is balanced etc.
I have been very pleased with this mod since I have performed it on my car.
Old 10-10-2004, 10:22 AM   #56 (permalink)
Send a message via ICQ to Orpheus Send a message via MSN to Orpheus Send a message via Yahoo to Orpheus
Now that I think about it, I think most of my noise came from the shifter "stop bolts". ... I decided to do away with them all together because they are not really needed. The stock shifter doesn't use them because the shift rods are travel limited.
thanks jub jub... i think i might give this mod a try. i tried using dynamat, and that stuff almost totally eliminates the noise... UNTIL it rips. it's not made for moving parts.
anyway, i am worried about removing those stop bolts. so, there are not problems at all with removing them, when using the hurst on a z06 transmission? why were they even there in the first place then?
thanks.
Orpheus is offline   Reply With Quote
Old 10-10-2004, 07:44 PM   #57 (permalink)
Good idea. However I just used layers of teflon tape on the knob threads and its been silent since day 1.
2000 Coupe MN6, ECS H/C
eamador11 is offline   Reply With Quote
Old 04-16-2006, 12:16 PM   #58 (permalink)
Thats a real good idea!
stangs400 is offline   Reply With Quote
Old 04-16-2006, 05:34 PM   #59 (permalink)
I thought so!
Old 05-06-2008, 09:48 PM   #60 (permalink)
Send a message via ICQ to GusVette Send a message via Yahoo to GusVette
Re: DIY: Silence that Hurst Shifter! (pics)
Very Good Info. I have a noisy Hurst Shifter and will try this.
Thanks,
Gus
GusVette is offline   Reply With Quote
Rate This Thread:
Shifter Boot for Hurst Shifter --> H20Vette C5 Z06 - Pit Road 2 08-22-2005 08:43 AM
shifter knob for hurst shifter zul8r C5 Z06 - Pit Road 6 09-03-2002 10:36 AM
Got my new Hurst shifter jone C5 Z06 - Grandstand 1 04-30-2002 08:28 AM
Hurst Shifter update, install link and comparison to other shifter - 3/4/02 RG Vendor Sales - C5 3 03-04-2002 08:34 PM
Moment of silence at 4:30pm est Manatee The Garage 4 12-03-2001 12:20 PM
