Old 10-25-2006, 11:10 AM   #16 (permalink)
I gotta try this!
Old 11-09-2007, 10:12 PM   #17 (permalink)
-X-
Re: Is your trunk starting to stick yet?
Trying this tomorrow.
-X- is offline   Reply With Quote
Old 01-10-2008, 05:05 PM   #18 (permalink)
Re: DIY: Is your trunk starting to stick yet?
This does work but when the trunk is shut the edges right above the adjusters stick up more than normal. I'm leaving it the way it is so the body panels all flow like they should...I can live with shutting my driver's door to get the trunk to open.
'99 Trans Am M6, cammed with nearly all bolt-ons making 427RWHP/380RWTQ...SOLD
New owner of an '02 EB ZO6 - ported TB, C6Z shifter
Civlant is offline   Reply With Quote
Old 01-10-2008, 05:32 PM   #19 (permalink)
Just put some WD 40 or some powdered graphite on the hinges and yu'll be good to go!
sig by GR8 White
'03 EB/mod blue VE interior, lots of performance mods! nasty cam, loud exhaust, lots of attitude! Any questions? Z06 Fest member III, IV, V, VI, and Winterfests 1&2 11.60@124.08 light'n 'em up!
Old 01-11-2008, 03:58 PM   #20 (permalink)
Mine has started doing that... I'll give this a try. Thanks for the tip
midnightinohio is offline   Reply With Quote
Old 01-29-2008, 07:22 PM   #21 (permalink)
Send a message via AIM to ZFoLyfe
my trunk lid opens about a half an inch if i'm lucky....no matter where i set the bumper stops......grrrr
ZFoLyfe is offline   Reply With Quote
Old 02-07-2008, 01:52 PM   #22 (permalink)
Send a message via AIM to KevZ06Torch
Mine also...and I guess it's NOT covered in the Major Guard extended warranty...
(I just found this out/ even though I had it worked on under the original 3 yr warranty)
ON another note/ did you see this thread was started YEARS ago when I was bantering back and forth with Cal?...LOL...I miss my roomie from the first Fest!!
~Kevin
KevZ06Torch is offline   Reply With Quote
Old 02-07-2008, 01:59 PM   #23 (permalink)
GR8 WHITE's Avatar
Dang Tom...Mine has been doing that for years and if I forget to shut my door, I just been using a key to sift it up carefully. Mine has been very uncooperative lately. But I will try the FRC TOM mod. Thanks!
GR8 WHITE is online now   Reply With Quote
Old 02-13-2008, 01:12 AM   #24 (permalink)
Just tried it myself and have gotta say thank you for the tip!
2003z06vette is offline   Reply With Quote
Old 02-13-2008, 07:26 AM   #25 (permalink)
rwd
FWIW, this is an old thread, and there were subsequent reports of stress cracks on the deck lid paint (in the area of the emblem, iirc) that were suspected to be related to the raised bumpers.
While raising the edges won't necessarily do that, it also requires added pressure on the lid to get the latch to hook, and the resulting forced flex of the lid might cause fatigue marks over time.
At the time, there were also threads about helper springs and other tricks, but the safest way is lube the hinges and weatherstrip and/or just use the air compression from closing the door (windows up) to pop it up.
Just an FYI.
rwd is offline   Reply With Quote
Old 02-18-2008, 10:47 AM   #26 (permalink)
Just an FYI.
Thanks for the info!!!!!!!!!!
Old 03-18-2008, 09:48 AM   #27 (permalink)
Nice
trayz06 is offline   Reply With Quote
Rate This Thread:
I want to stick around here... gbjerke The Garage 15 09-03-2007 05:47 PM
it won't stick JtownZ06 Vendor Sales - C5 1 05-28-2003 10:26 AM
Will 305's stick out myZ06moves C5 Z06 - Pit Road 4 03-09-2003 09:35 PM
Is your trunk starting to stick yet? FRC Tom C5 Z06 - Grandstand 9 12-18-2002 09:05 PM
Oil Dip Stick Richard C5 Z06 - Grandstand 19 05-05-2002 05:31 PM
