DIY: Is your trunk starting to stick yet?
24K views 35 replies 30 participants last post by  RedTexasZ06
#1 ·
After a while if you use your trunk a lot like I do and after owning way to many FRCs there is an easy fix. At both ends of the inside of the trunk lid there are spring loaded rubber bumpers adjust them out by turning them to the left and poof your trunk will open like new so you do have to try to stick your fingers under or like I used to do open and close the drivers door so the air preasure would force it up.
#35 ·
I noticed this on my Z06 the day I got it. I owned an fbody a while back so I was not stranger to trunks/hatches sticking. I either do the door method like you mentioned or I push down on the front part to leverage up the back to get my fingers underneath it.
I will be adjusting these when I get home though! Thanks
