C6 Z06 OEM wheels on C5 z06 questions??
7K views 5 replies 6 participants last post by  06venom
#1 ·
hey guys,
i've been searching for info and calling around for about 3 days now and can't seem to get a definitive answer.
I have an '03 z06 and a set of OEM c6 z06 chrome wheels from a 2007 z that I want to swap on. Some places are saying they won't fit at all, others are saying since it is a 12" wide wheel I can only fit 305's and it would be better to stick with stock wheels since I can fit 315 Drag Radials on those.
I will be around 600whp+ and hopefully over 700 on e85 so I'm thinking anything smaller than 315's won't hook up.
So: Can I use those c6 z06 OEM rims without any problems? Suggestions?
Any help would be great! Thanks!
#5 ·
could you post a pic of your c6z wheels/tires on your c5z06, I've been considering this as well--does it rub on bumps, can you turn the fronts all the way right and left? thanks
#6 ·
I have also been doing a lot of research on this the past few days. I have a 04 Z06 and would like to get a set of C6 Spyders for mine. Everything I have been reading says they will fit but just stick out 3/4 to 1 inch. I'm also wondering if there will be other issues with the speedo or anything else. Not to many pictures out there of C5 Z06's with C6 Z06 wheels.
