Go Back   Z06Vette.com - Corvette Z06 Forum > Supporting Vendors > Sun Automobile
Old 06-16-2009, 02:23 PM   #1 (permalink)
SunAutomobile's Avatar
Hyper Ground System - How does it work???
What is it?
Hyper Ground System is a new generation tuning system designed to provide a direct, low-resistance ground path from engine components to the battery. It allows the entire electrical system to perform at greater efficiency, which can result in:
- increased hp
- increased torque
- improved fuel efficiency
- stabilized idle
- brighter lights
- quicker engine starts
- reduced emissions
- reduced audio noise
How does it work?
In any electrical system, electric current flows from the positive terminal to the electrical components, and back to the battery through the negative terminal. However, the way that the factory (stock) grounds are set-up, the electrons must travel through the steel and/or aluminum components in the car to complete the circuit, which creates much electrical resistance (steel/aluminum are not the best materials for electrical conductivity). This resistance disturbs the flow of electricity to a degree that electrical components such as ECU, lights, spark plugs. etc, cannot perform at maximum efficiency. In order to get the highest performance out of any automobile, it is necessary to achieve an efficient flow of electricity with the least resistance along its electrical circuit. By providing a direct ground path using highly conductive 99.99% pure copper, this electrical resistance is reduced greatly (as much as 10 times!), resulting in an ultra-low resistance ground path. In short, Hyper Ground System affects the electrical system similar to how a high performance intake and exhaust system affects the mechanical system, by scavenging power which would otherwise be lost due to system inefficiencies.
What makes it so special?
Sun Auto produces the Hyper Ground System to an exacting level of utmost quality. The cables are made to our proprietary design, constructed using thick-gauge 99.99% copper, with 1,477 strands per cable. Since the electrons only travel on the outside of the strands, many strands are necessary to maximize the electron flow. The cables utilize multi-layered shielding, which is specially blended to provide minimum electron leakage as well as to withstand engine room temperatures and protect against discoloration. Terminals are available with gold-plating, for better electrical conductivity and protection against corrosion. The Hyper Ground System also uses a patented “daisy-chain” method to connect directly from the cylinder head and other points under the hood to the battery, to provide an ultra-low resistance ground path. The kit comes in 3 universal sizes to fit any type of vehicle, and is effective for use in anything from bone-stock to fully modified vehicles. Aside from the universal kits (5 cables in different lengths), Sun Auto offers a lineup of car-specific kits, which are tailor made to fit a specific vehicle.
What will fit my car?
Hyper Ground System will fit virtually any vehicle:
Universal S-Type: for most 4 cylinder and V6 vehicles
Universal M-type: for most inline 6, V8 and larger vehicles
Universal L-type: for most cars with front engine/rear battery configuration
Optional wires in varying lengths are also available to supplement the universal kits and/or for custom applications.
How much horsepower/torque will I gain with Hyper Ground System
As with any product, the amount of benefit gained will vary between applications. The average gain seems to be between 3-6 horsepower. Hyper Ground System is not a product that is used to boost your vehicle's power; it is designed to increase efficiency in the electrical system to help your vehicle operate at its full potential. A good example would be to examine the effect of changing the intake and/or exhaust system of your vehicle. By allowing the car to "breathe" easier by installing a higher flowing exhaust and/or intake system, horsepower which is otherwise lost to system inefficiencies is restored. Similarly, Hyper Ground System affects your electrical system in the same manner. So, how inefficiently your factory electrical system is operating in its current condition will determine how much power can be restored by installing Hyper Ground System.
SunAutomobile is offline
Old 06-16-2009, 08:15 PM   #2 (permalink)
RocketSled's Avatar
Re: Hyper Ground System - How does it work???
The answer is "it probably doesn't". Some cars have notoriously crappy Grounding systems and upgrades like this can help. But usually, these situations are found on cars that weren't originally high performance designs.
In my opinion, you can put this in the same category as "Monster Cable". Paying extra for lower impedance conductors only matters if your exceeding the capabilities of the existing conductors. The "benefit" is even more dubious in the context of a computerized engine management system. A PCM doesn't work any better with voltages any better than the minimum needed for it to function, it works exactly the same. The PCM either works or it doesn't work. Period.
I suppose that better Grounding to the Coils could result in minor improvements in Spark voltage, but that's about all I could think would benefit.
C6!
RocketSled is offline
Rate This Thread:
How to find a Ground in your electrical system? NavyPhrog C5 Z06 - Pit Road 6 09-26-2006 04:47 PM
ok so where do we get Hyper Silver wheels?? jason1200 C6 Z06 - Pit Road 1 02-03-2006 12:49 PM
hyper silver wheels jason1200 C6 Z06 - Pit Road 2 02-02-2006 10:58 AM
Which header system + x-pipe will work with 2.5" GHL mufflers? SupercarFreak C5 Z06 - Pit Road 6 06-23-2005 03:51 PM
Hyper LUB miami993c297 C5 Z06 - Grandstand 2 01-06-2004 10:51 AM
» Latest Auto News
Furious Fuchsia Dodge Challenger Celebrates 40 Years of a Muscle-Car Icon
Dodge is once again releasing a new special edition versions of its
Chicago Preview: Nissan 370Z 40th Anniversary Edition Set for World Premiere in Chicago
Just last week we thought we’d have to wait for the New York
Chicago Preview: 2011 Infiniti M37, M56 Set for Public Debut
While the media was given a sneak peak at the all-new 2011 Infiniti
» New Car Reviews
2010 Lamborghini LP560-4 Spyder Review
With Lambo's new LP560 Spyder, taming the bull has never been so easy,
2010 Nissan Pathfinder SE 4x4 Review
Nissan's rugged Pathfinder is an old-school standout
2010 Chicago Auto Show Preview
The Chicago Auto Show might not have the media hype of such events as
2010 Toyota Camry SE V6 Review
An SE trim level adds a little sport to the Camry, making living with
2010 Subaru Legacy 2.5i Premium PZEV
Subaru's 2010 Legacy gives up some of the brand's more endearing
