Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > Member Sales - Parts & Cars
Old 02-16-2004, 01:05 AM   #1 (permalink)
ASP underdrive pulley
This is an ASP pulley for a c5. This unit came off my car, it has about 4k miles on it. It has a big nick at the top from the install (done by local shop). I was worried about this so I took it to my machine shop and had it tested for 0 balance and it came out perfect (hence the OK written on it). I am selling with a brand new ARP reusable balancer bolt. Asking 185.00 shipped obo.
PS Sorry its so dirty, I should have cleaned it up a bit
Torch Red ***New combo in the works*** Keith Craft built 383 stroker, solid roller cam 260/262 .672/.689, MTI stage III heads, jesel adjustable rockers, C5R valve covers, FAST 90mm intake (port matched), 90mm throttle body, Kooks 1 7/8” headers, 3” xpipe, ARP studs throughout, Cometic head gaskets, Evans no pressure water pump and coolant, Breathless shifter w/ Hardbar, Poly bushing kit, VBP poly motor mounts, McLeod adjustable master, Exedy twin disc clutch/pressure plate, Hawk HPS pads, SS brake lines, DRM carbon brake ducts, Fluidyne 4 core radiator, Carbon Fiber rear fenders (1" wider than stock), Lingenfelter high output steering pump, Baer tracker toe links, Caravaggio seats, CCW 19x10, 19x13 wheels.
jmenge is offline   Reply With Quote
Old 02-16-2004, 06:14 AM   #2 (permalink)
Is it a 10% reduction pully?
ASP underdrive pulley, WOW eviLS6 C5 Z06 - Pit Road 8 03-09-2006 10:47 PM
FS: New ASP underdrive Pulley setup ownedya Member Sales - Parts & Cars 0 08-15-2005 12:13 PM
WTB: ASP Underdrive Pulley dbhajek Member Sales - Parts & Cars 0 05-16-2005 01:14 PM
ASP Underdrive Pulley Search!! Dissident The Garage 8 04-19-2005 02:06 PM
ASP 25% Underdrive Pulley w/ Belts and New GM Bolt C5kid Member Sales - Parts & Cars 4 04-17-2004 04:18 PM
