Like the topic says. After thinking long and hard, I finally decided to sell my baby. This car is ready to go and should be plenty of power for most. I just don't drive the car as much as I should so it should go to someone who will drive it all the time. This car will make an excellent daily driver. I'm sure you could find a few cheapier cars out there but not many with the amount of mods at this price. If you have any questions, please give me a call @ 520-249-4308.
Thanks,
Tony
Car:
2002 Millenium Yellow Z06
Milage:
42,xxx (mostly highway)
Price:
$29,000 obo.
Engine:
SLP Black wing intake
Fast 90MM intake (Ported by Tony Mamo)
LS2 90MM TB (Ported by Tony Mamo)
Custom comp ground cam (232/236 .595 .600 @ 112 LSA XER Lobes)
AFR 205 Heads (stock C.R.)
Double springs with titanium retainers
Comp Hardend push rods
Double roller timing chain
SLP underdrive pulley
Mecco valve cover breather
MSD 8.5MM plug wires
Brand new ported LS-6 oil pump
Meziere electric water pump
WCC catch can
Exhaust:
Kooks 1 3/4 long tubes
X pipe with high flow
B&B Bullit cat back
Fuel system:
30LB injectors
Nasty billet fuel rails
240 intank fuel pump
Drivetrain:
Stage 5 bulletproof M12 tranny
New 1-2 Billet Slider
New 3-4 Billet Slider
New 5-6 Billet Slider
New Brass Reverse synchro
Carbon Fiber Synchros
3-4 Billet Keys
New Bronze Fork Pads for 1-4 Gear Forks
Steel 1-2 Forks
Steel 3-4 Forks
Mikronite Finishing on 1-4 Gear
Mikronite Finishing on 1-2 Slider
Mikronite Finishing on 3-4 Slider
New Main Shaft
New Bearings
Hardend Output shaft
New LS7 clutch
New Slave
New Master
Shortened C5 shifter w/C5 crossed flags shifter ball.
Appearance:
HID Head light 10000K
PIAA fog lights
Breathless performance Heat extractor hood
Carravagio spoiler
Billet silver rings around gauge cluster
Loyds embordered mats with flags
Yellow stiching on console lid and shifter boot
Complete blue LED Dash conversion with doors as well
Painted Rear Fascia (black)
Halo LED tail lights
5% window tint
Carbon Fiber rear duct brakes
lowered 2" all the way around
Raptor shift light (Blue)
Stereo:
Eclipse AVN5495 Nav unit 6.5" DVD Navigation touch screen
Rainbow Audio ProVanadium w/Kick bass (3way) in the doors
Wheels/tires:
FRONT 18 X 9.5 Chrome Z06 wheels W/275 35 18 Nitto 555’s.
REAR 18 X 12 Chrome Z06 wheels W/335 35 18, Nitto 555 DR’s
Brakes/Suspenison:
Cross drilled and slotted rotors
Hawks pads all 4 corners
Stainless brake lines
Bear sway bar links
Power:
N/A: 454rwhp/403 ft. lbs. (91 Octane)
