As some of you know, I have a project car that I have been working on and had this LS6 sitting in place for my '70 Camaro but stumbled onto a buddy's C5r block and grabbed it for the car.
Now I need to sell the current setup and someone will get to grab a real good deal.
Here are some details -
I purchased a '03 LS6 engine from Phoenix Performance that Joe said had 1700 miles on it. I then sent it down to Greg, AntiVenom here, and had one of his CNC'd 243 heads and cam packages put together on it.
The heads have been fully ported and set up with all the good stuff. They have been angle milled and are right at 11.5:1.
The cam is a 232'/ 236', with .595/ .601 on a 114+4 lsa, nothing to be dreaded for drivability. Holdger and Jim Lembo have the same packages, if you'd like to ask them regarding street attitudes. I hope they don't mind if I reference them .
The engine has not been fired since Joe pulled it out of the Z06 at Phoenix but after the work from AntiVenom should be a fairly stout performer....expect ~440-450 rwhp.....maybe a bit more, depending.
I will need a few pieces off the block, but you can replace them with your pieces if you're doing a swap out.
The intake, coil packs, oil pan and windage pieces will not be included. I will include the accessory brackets along with new P/S pump, alt, A/C compressor, water pump, etc.
$ 6,000 will get it shipped to you or your shop of choice for installation. Basically, the cost of the H/C and you're getting a LS6 included.
Email or PM if you're interested. This is a great motor for a resto project too!!
'03 EB/mod blue VE interior, LME-LS3 Stroker, AFR 225's and a nasty cam from Pete at V-MAX, 3" custom Powerstick exhaust and lots of attitude! Any questions? Z06 Fest member III, IV, V, VI, and Winterfests 1&2. new times coming soon!
I could have used that deal around Christmas Eve when I dropped a valve. Then Jimbo and I could have had a duel !!!!!!!!!!!!
Pitt
Oh you and Jimbo are going to duel alright!!! I am pretty sure that the 416 was going in this weekend..........hmmm, that's a good reason to give him a call....check on progress.
I wish I had known back then that you were in search of, we could have definately worked something out...........but then you wouldn't be sportin' that 383 you got there buddy!!!
