Ive got this stuff when I got the car and getting rid of it to replace it with some other stuff. Im not a fan of audiobahn products and this amp is way too big and much for my taste in a z06vette.
The amp is an A2300HCT audiobahn amp.
http://www.mandrelbends.com/MyZ06/amp.jpg Theres the picture of it.
Specs on it are:
2400x1 @ 1ohm mono
1200x1 @ 2ohm mono
600x1 @ 4ohm mono
900x2 @ 1ohm stereo
600x2 @ 2ohm stereo
300x2 @ 4ohm stereo
High Current Circuitry
PWM MOSFET Power Supply
Double-Sided Glass Epoxy Circuit Board
S/N Ratio: >100dB (+/- 1dB)
Frequency Response: 10Hz – 20KHz
Remote Bass Control With Blue Backlit Knob
Variable 24dB High-pass Crossover: 50Hz – 750Hz
Variable 24dB Low-pass Crossover: 30Hz – 120Hz
Variable Subsonic Filter: 20Hz - 45Hz
Variable Bass Boost: 0 – 18dB
Variable Bass Boost Frequency: 40Hz – 100Hz
RCA Throughput Connections
4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset
Dual Cooling Fans
VU Meters Indicating Output Response
Cobalt Blue Illumination
High Gloss Chrome-Plated Finish
nickel-plated block terminals
The cap is a ACAP301Q model. Its a 3farad digital cap.
Picture of that is
http://www.mandrelbends.com/MyZ06/cap.jpg
Specs on the cap are:
3 Farad Capacity
New Amp Style Design
Two 1/0 Gauge Inputs
Eight 4 Gauge Outputs
Remote Turn-on Distribution
Four Maxi Fuses
24 Volt Nominal - 28 Volt Surge
Auto on / off Blue L.E.D. Four-Digit Readout
Electronic Polarity Protection Circuit
Overvoltage Protection Circuit
Soft on / off Circuit
Aluminum Heat Sink with Chrome Plated Cover
Wooden Gift Box
Dimensions: 12 1/2”(W) x 2 3/4”(H) x 10 1/2”(D)
Im asking $600 for the two. This was used to drive a JL12W7 which is more than enough power to drive that sub.
dsuthar@adelphia.net
Dixit
