Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > Member Sales - Parts & Cars
Old 01-02-2005, 01:17 PM   #1 (permalink)
FS: MB Quart QM 160 speakers
I have a set of MB Quart 6 1/2 speakers. I believe these came in a component set but I can't find the paperwork on them. They are 6 1/2" mid drivers with tweeters, both in very good shape only used for about 6 months. These are the Q series so they sound awesome, rared at 130W RMS, 4Ohm per speaker. Asking 50.00 + shipping. Thanks
Torch Red ***New combo in the works*** Keith Craft built 383 stroker, solid roller cam 260/262 .672/.689, MTI stage III heads, jesel adjustable rockers, C5R valve covers, FAST 90mm intake (port matched), 90mm throttle body, Kooks 1 7/8” headers, 3” xpipe, ARP studs throughout, Cometic head gaskets, Evans no pressure water pump and coolant, Breathless shifter w/ Hardbar, Poly bushing kit, VBP poly motor mounts, McLeod adjustable master, Exedy twin disc clutch/pressure plate, Hawk HPS pads, SS brake lines, DRM carbon brake ducts, Fluidyne 4 core radiator, Carbon Fiber rear fenders (1" wider than stock), Lingenfelter high output steering pump, Baer tracker toe links, Caravaggio seats, CCW 19x10, 19x13 wheels.
jmenge is offline   Reply With Quote
Old 01-02-2005, 10:59 PM   #2 (permalink)
Send a message via AIM to MrKool Send a message via MSN to MrKool Send a message via Yahoo to MrKool
do your speakers look like these?
MrKool is offline   Reply With Quote
Old 01-02-2005, 11:20 PM   #3 (permalink)
Hi,
Yes, those are the exact same speakers, the tweeters are mounted to the mids but can also be removed and mounted seperately as well. Thanks
Old 01-03-2005, 07:29 AM   #4 (permalink)
i interested can i you email me a number i can call you at!
l8back2003@yahoo.com
l8back is offline   Reply With Quote
Old 01-03-2005, 08:48 AM   #5 (permalink)
Email sent,thanks
How to best measure one quart over? Olitho Racing 13 10-23-2007 02:10 PM
Do I Need the Extra Quart? Bob C5 Z06 - Pit Road 21 07-05-2004 08:34 PM
Drain one quart? Bob C5 Z06 - Pit Road 11 05-09-2004 08:54 PM
FS: Bose Speakers from 2002 Z06 - 4 Speakers blackSix Member Sales - Parts & Cars 0 01-03-2004 12:10 PM
Running a quart over... dimer0 C5 Z06 - Pit Road 8 08-03-2001 07:08 PM
