Meziere electric water pump
This water pump is brand new. Its black in color. It was test fit on my new shortblock but has never been run or seen water (or wired to 12V). Asking 425.00 obo.
Torch Red ***New combo in the works*** Keith Craft built 383 stroker, solid roller cam 260/262 .672/.689, MTI stage III heads, jesel adjustable rockers, C5R valve covers, FAST 90mm intake (port matched), 90mm throttle body, Kooks 1 7/8” headers, 3” xpipe, ARP studs throughout, Cometic head gaskets, Evans no pressure water pump and coolant, Breathless shifter w/ Hardbar, Poly bushing kit, VBP poly motor mounts, McLeod adjustable master, Exedy twin disc clutch/pressure plate, Hawk HPS pads, SS brake lines, DRM carbon brake ducts, Fluidyne 4 core radiator, Carbon Fiber rear fenders (1" wider than stock), Lingenfelter high output steering pump, Baer tracker toe links, Caravaggio seats, CCW 19x10, 19x13 wheels.
