Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > Member Sales - Parts & Cars
Old 08-15-2007, 07:33 AM   #1 (permalink)
N2O Progressive Controller NX Maximizer by FJO PN: 15959
BRAND NEW IN BOX, JUST OPENED TO LOOK AT SELLING OUT OF NITROUS AND MODS..$600 SHIPPED
***edited***
·Dual Stage independent output channels (independent profiles for each channel)
·Time-based ramped delivery of nitrous and fuel (unique programmable delay and ramp times for up to 8 gears)
·RPM-based delivery of nitrous and fuel (unique programmable curve for up to 8 gears)
·Throttle-based modifier of nitrous and fuel (reduce nitrous delivery by up to 35% based on throttle position)
·LEAN threshold automatic “cut-off ” when using FJO Wideband system
·Programmable RPM trigger point and cutoff
·Programmable MAP cutoff (when using nitrous as an "anti-lag" system)
·Nitrous pressure sensor input
·Built-in MAP sensor reads from vacuum to 48 psi of boost
·Gear detection for manual and automatic transmissions
·Inputs for arming switch, bottle heater enable switch, 2 trigger switches, throttle position, tach signal, nitrous pressure, and Air/Fuel Ratio (narrow or wideband)
·2 configurable outputs for either: integrated bottle heater control, integrated bottle opener control, automatic N2O purge function, or status LED
·2 ignition retard outputs
·Digital communication port for PC or digital gauges
·Easy to use graphic set-up menus and datalogging using Windows™-based PC
·High current 2-channel solenoid driver
Details
Weight 10.00 lbs
Price: $949.00 (€ 825.63)
clhaka is offline   Reply With Quote
FS: NX maximizer control unit Brad Maynard Member Sales - Parts & Cars 1 09-07-2006 08:26 AM
FS: Brand New NX Maximizer ccajun4real Member Sales - Parts & Cars 3 09-07-2006 08:23 AM
NX Maximizer Launchn C5 Z06 - Forced Induction & Nitrous 4 04-08-2004 03:25 PM
FS: NX maximizer control unit Brad Maynard Member Sales - Parts & Cars 0 01-27-2004 08:49 AM
progressive power harleydenson C5 Z06 - Grandstand 2 08-13-2003 04:20 PM
