New BeCool radiator
This is a brand new BeCool radiator. I purchased it but it never made it on to the car. You can't find these for under 550.00. Asking 425.00 + shipping obo. Thanks
Torch Red ***New combo in the works*** Keith Craft built 383 stroker, solid roller cam 260/262 .672/.689, MTI stage III heads, jesel adjustable rockers, C5R valve covers, FAST 90mm intake (port matched), 90mm throttle body, Kooks 1 7/8” headers, 3” xpipe, ARP studs throughout, Cometic head gaskets, Evans no pressure water pump and coolant, Breathless shifter w/ Hardbar, Poly bushing kit, VBP poly motor mounts, McLeod adjustable master, Exedy twin disc clutch/pressure plate, Hawk HPS pads, SS brake lines, DRM carbon brake ducts, Fluidyne 4 core radiator, Carbon Fiber rear fenders (1" wider than stock), Lingenfelter high output steering pump, Baer tracker toe links, Caravaggio seats, CCW 19x10, 19x13 wheels.
