Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > Member Sales - Parts & Cars
Old 01-17-2003, 09:59 AM   #1 (permalink)
? on a sending unit
First of all, I would like to say I am glad to have come across this site. Really interested in getting together with some people that might be in my neck of the woods.
Alright, I was curious if anyone has had a problem with there 'sending unit'. This is an item that actually measures the level of gasoline in your tank and sends the message to your needle on the dash. I have my car in service right now getting BOTH of them replaced. Once my needle hits a 1/4 tank left, it drops to E. Has anyone had/heard of this problem?
And I guess since its my first thread I might as well add this too. Anyone have a subtle knocking noise when at a stop light for instance. It comes and goes and engine temperature does not effect it. I really don't know how else to discribe it. Just wanted to hear yall's $.02.
Thanks in advance.....
T-MAN is offline   Reply With Quote
Old 01-17-2003, 10:13 AM   #2 (permalink)
NYCHASM's Avatar
Welcome to the family T-MAN. I think you'll like it here.
Gas tank sending unit failure is pretty common. Lots of us have had this problem. Once the sensors are replaced you should be okay. One of the things that was a problem was the gasoline actually corroding the sensor. I would assume the issue was fixed when GM learned that it was such a common problem.
The noise you hear when stopped at a light may be the infamous "exhaust jingle" that a lot of Z06's are prone to. Something apparently inherent in the system and probably related to the "H" pipe.
If you do a search for both of these concerns, 'gas tank sensors' and 'exhaust jingle', I'm sure you'll find more info than you care to know!
Welcome aboard. Enjoy the site.
Charlie
Old 01-17-2003, 03:07 PM   #3 (permalink)
Thanks Charlie.....damn that was fast. Thanks for the heads up on the search too.. "more info than you care to know" You hit that right. Although you hate to have stuff wrong with your baby, it gives you that warm fuzzy feel'n knowing others are going through the same problem...
...L8R
oil pressure sending unit specs 03 Z06 C5 Z06 - Pit Road 1 06-25-2005 06:53 PM
Oil pressure sending unit problem?? Terry S C5 Z06 - Pit Road 9 02-16-2005 07:58 AM
Suggestions on sending flowers on Feb.13 T-MAN The Garage 13 02-04-2004 08:06 AM
Thinking of sending back G tech... Joslyn C5 Z06 - Grandstand 10 09-04-2003 08:05 PM
Sending Unit Went Bad????? FiveOJoe C5 Z06 - Pit Road 9 04-14-2003 07:13 PM
