Originally posted by Zoomin
How much does it weigh, capacity, brakes on both axles?
All aluminum construction 6061 T6 high strength alloy frame, components, ramps, except floor. Floor is 5086 or 6061 and fenders are 5052.
Both fenders are removable with stainless steel hold-downs.
Four recessed tie down rings, 5,000 lb. capacity each.
Four 205 X 15 L.R.C. (6 ply rated) heavy duty radials, 1,820 lb. capacity each. See optional 10,000 lb. model and other models.
Attractive and durable heavy duty powder coated wheels.
Two 3500 lb. rubber torsion axles, brakes on both axles, and independent suspension.
Break-away kit and battery with heavy duty safety chains and hooks with safety catch.
Full floor, high strength, 1/8" diamond plate or 5-bar, with I-beam cross-members at 12" O.C. cross welded continuous.
Two 6'x16" ramps with slide-in storage: lightweight and very strong.
ICC lighting (sealed beams like a semi!) w/ anti-electrolysis connections.
83" between fenders on 7,000 lb. models and 81" between fenders on 10,000 lb. models.
7,000 lb. GVWR with 2 5/16" coupler (2" coupler available at less GVWR on one car models).
Running boards are standard on taper-front models, optional on square-front models.
