My newly acquired 02/Z06, when I hit the door lock switch/fob to unlock the doors, the passenger door will lock but won't unlock. The drivers door functions properly.
I'm trying to avoid the stealership, if anything i'll open the door panel up and try and figure it out myself, im no dummy when it comes to cars, I was just trying to get a head start just in case someone else has had this issue.
Any suggestions?
Thanks.
vnt
Mine is doing the same thing, I was thinking about taking off the door panel and adding a little lube to see if that would help.
It starts to unlock but only goes so far, same with the fob and door control, just hanging up somewhere. :oo:
Peelin' Out
Ted
Born on Date-10-12-01, MCM Hood, ACI Front Spoiler,Caravaggio Rear Spoiler, Kooks 1 3/4 LT,Vortex CAI Stingers, Hurst Shifter /Flameball, EE Tunnel Plate, RD Harness Bar/5 point harness, V-1 and Cobra 75 CB
Any suggestions?
Thanks.
vnt
Is there a child safety feature? I never looked..
He who dies with the most toys is nonetheless dead.
Same problem here. Happens with the drivers side door. It will unlock with the fob or by pushing the button on the door but it doesn't always lock. First time I noticed it was when I set the alarm off by opening the door after the door didn't lock. Luckily I was at home when it happened. I've been double checking the locks to be sure the car is locked when I take it anywhere. When the fob/button doesn't lock the door, I've been doing it manually. I'm going to try a little WD40 like what was mentioned on the other thread. Hate the thought of having to take it to the dealer for this.
Add me to the list as well... Passenger's side hasn't unlocked in a year and a half. Driver's side is fine and passenger's side will lock with no problem but getting it to unlock using the fob or the armrest button is useless. Any chance of us getting a group rate on the actuator motor... Al
I'm going to open it up this weekend and lube her up with some wd-40 and White Lithium Grease and hopefully that fixes it. I really don't want to spend $$ on a actuator unless I have to.
Plus I need to clay bar/wax/polish the car this weekend.
