Old 03-28-2008, 09:16 AM   #1 (permalink)
Braille B2015 battery ok for my car?
Been thinking of ditching the Optima Yellowtop battery. It's heavy and fairly crap IMHO. I was thinking of going for a Braille B2015, but was wondering if this would be sufficient for my motor; forged 383, D1SC, ECS fuel system, heads/blower cam... Anyone have any thoughts? I see Braille also makes a heavier duty version (although it weights more) called the B3121. Would this be better?
MY 2003, 733RWHP, 655RWTQ, forged 383, D1SC procharger, Kooks headers, heads/cam, LG coilovers, lots of other stuff
Chris Holmes is offline   Reply With Quote
Old 03-28-2008, 10:09 AM   #2 (permalink)
extanker's Avatar
Re: Braille B2015 battery ok for my car?
which one has more CCA,s
Old 03-28-2008, 10:16 AM   #3 (permalink)
550 CCA for the B3121 and 425 CCA for the B2015. However, both of these are well below the yellow tops 750 CCA.
Old 03-28-2008, 10:47 AM   #4 (permalink)
Chris, I have the B2015. No issues so far. However, my car is stock.
The B3121 is only 6 lbs heavier than the B2015. You will not notice the difference in weight, in my opinion, but you will at least have some peace of mind regarding the greater CCAs.
But unless I am mistaken, CCAs only apply to temperatures at 0*F. Does it even get that cold in your area. And would you be driving in those temps anyway?
I'm far from a battery expert, but it seems to me that CAs are more significant in this case. How do the Optima's CAs compare?
B2015 Specifications:
Casing: Polymer Plastic
Weight: 15 lbs
Length: 6.8
Width: 3.4
Height: 6.1
Pulse Cranking Amps: 1067
Cranking Amps: 574
Cold Cranking Amps: 425
Amp Hour Rating: 21
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
B3121 Specifications:
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Pulse Cranking Amps: 1380
Cranking Amps: 742
Cold Cranking Amps: 550
Amp Hour Rating: 31
"I put a dollar in one of those change machines. Nothing changed." ~George Carlin
4 good Toyo T1Rs - back in business / CAGS Defeat / Tint / Soon to be Lowered / DEAD Braille, now --> Walmart Battery / Seat Bolster Mod / HPDE Checklist
Old 03-28-2008, 12:33 PM   #5 (permalink)
I live in Maryland, and it doesn't get that cold to be honest. The values for CA are as follows;
Braille B3121 - 742
Braille B2015 - 574
Optima Yellow Top - 870
Old 03-29-2008, 02:27 AM   #6 (permalink)
extanker's Avatar
go with the opt
Old 03-29-2008, 03:20 AM   #7 (permalink)
Originally Posted by extanker View Post
go with the opt
i agree
gasboy is offline   Reply With Quote
Old 03-29-2008, 10:23 AM   #8 (permalink)
JustinG's Avatar
I've hard the 11.5lb for over 2 1/2 years now, works great! The 15lb will work fine.
02 TR/BLK Z06 -- V1 | Hurst/Hurst Black knob | Braille Battery | Callaway 78mm Billet Throttle Body | Callaway Honker | Elite Engineering radiator screen | Diablo Predator | Ceramic coated AR Headers
03 SGM/BLK Vert. (Wife's) -- Z06 Titanium exhaust | CF Braille Battery | Diablo Predator | Callaway Plug Wires | NGK TR5 Plugs | Shaner S2 Throttle Body
JustinG is offline   Reply With Quote
Old 03-29-2008, 12:23 PM   #9 (permalink)
Well I am not a Wal-Mart fan, but I have four of their EVERSTART MAXX batteries in use:
One in my 1967 El Camino with a 572 crate engine, A/C and after market stereo for two years. The Battery is located in the rear behind the cab and to date I have not had any problems. The car is not driven during the winter but I do have a battery tender on it.
I have another one of these in my 63 Corvette, not driven in the winter.
One in an LS5 Chevelle, this one is four years old.
And one in a 68 427 Corvette. No problems with any of them.
The specs are:
1000 cranking amps to 32deg f.
875 cold cranking amps
3 - year full replacement
Cost $60.00. ea.
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Braille battery for Z06 screamindman C5 Z06 - Pit Road 9 03-14-2008 02:27 PM
Braille battery on the way! black96ws6 C5 Z06 - Pit Road 10 03-04-2008 10:06 PM
Braille Battery install pic!!! JustinG C5 Z06 - Pit Road 69 02-04-2008 07:52 AM
BRAILLE Batteries - Lightweight Carbon Fiber Ignition_key Member Sales - Parts & Cars 3 12-14-2007 11:44 AM
Braille Battery issues stellablu C5 Z06 - Grandstand 6 02-12-2006 08:43 AM
