Old 09-03-2003, 08:09 AM   #1 (permalink)
Can you disable the passengers airbag?
A co-workers father just purchased a 1999 C5 vert. Black on Black with 8100 miles.
He has 2 small Grandkids ages 5 & 7. They will be heartbroken if they could not ride in it. The laws state that no child under the age of 12 (I thought it was a height issue, not age) can sit in the front seat of a car that has a passenger airbag.
Is there a way to temporarily disable the airbag?
Matt
1998 Torch Red Trans Am. 2002 LS6 405hp engine. Lowered, M6, Torque Thrust II's, SunCoast Creations RamAir hood.
12.17, 114.00, 1.85
367rwhp
358rwtq
Hunter98TA is offline   Reply With Quote
Old 09-03-2003, 08:26 AM   #2 (permalink)
Check the glove box. That's where it is on the Z.
Si vis pacem, para bellum.
Old 09-03-2003, 08:39 AM   #3 (permalink)
NYCHASM's Avatar
Just to expand a little on the previous post, you need to find the passenger side airbag switch that uses the ignition key to disable. As posted, it should be in the glove box.
Good luck,
Charlie
Old 09-03-2003, 09:00 AM   #4 (permalink)
Thank you Gentlemen. The RugRats will be happy.
Matt
Old 09-03-2003, 09:57 AM   #5 (permalink)
FYI, I don't think that year had the airbag disable. Even if it's not there, you can get the wiring kit from any GM dealer and install it. The other option would be to pull the airbag fuse, which will of course set a code and turn on the warning light in the dash cluster.
Evan
2001 TR Z06
356RWHP, 344TQ
www.Z06vette.net
EvanZ06 is offline   Reply With Quote
Old 09-03-2003, 10:02 AM   #6 (permalink)
That is consistant with what I have heard. Switch did not become standard in the glove box until 2001 (I think).
Old 09-03-2003, 06:52 PM   #7 (permalink)
It was added late in the production of the 2000s........ I believe January 2001. The upgrade kit has the switch in the glovebox and the indicator light on the console. The kit is around $115 and is not a quick install. Here is a link for the only information I could find on installing this kit:
http://97vette.com/howto/airbag/index.html
As a temporary fix, you can pull SDM fuse#16, which kills the entire airbag system......... including the driver's airbag. I would only pull and replace this fuse with the ignition off.
TexasRedZ06 is offline   Reply With Quote
cags disable soldmystang C5 Z06 - Pit Road 10 02-27-2005 10:14 PM
Grease on drivers and passengers windows dryforkz06 The Garage 8 06-03-2003 08:39 AM
Passengers window dead??? aclar C5 Z06 - Pit Road 16 04-16-2003 10:46 AM
Cool Idea? 2004 Chevy Malibu Maxx to offer treats for back-seat passengers JBsZ06 The Garage 0 09-19-2002 05:25 AM
Drivers, Passengers, Guests - Homestead - May 18 SteveNix C5 Z06 - Grandstand 6 05-07-2002 07:12 PM
