Old 05-30-2005, 09:38 PM   #1 (permalink)
Comp Mode?
I am confused about the modes?
The normal mode on startup gives you?
If you turn the TC of do you still have active handling?
If you go into Comp mode what happens?
I thought I had it all figured out, now I confused myself LOL!
I don't want to find out the hard way.....
dheller1 is offline   Reply With Quote
Old 05-30-2005, 09:45 PM   #2 (permalink)
NCM Ambassador
Zippy's Avatar
The best answer lies in your owner's manual....check it out. I've had five new Vettes since 1999m and I still learn new things from the manual.
Zippy
'08 427 Limited Edition Z06
Old 05-30-2005, 09:46 PM   #3 (permalink)
You have 3 choices
All on
All off
or Competitive Mode which is AH on TC off.
Old 05-30-2005, 09:51 PM   #4 (permalink)
This thread has a little more info
No competition mode? Weak power?
Old 05-30-2005, 09:51 PM   #5 (permalink)
I read the manual that is where I got more confused, I think I have it all figured.
Normal on start up
One tap of the button all off
Hold button Comp mode ah on and tc off
Old 05-30-2005, 09:54 PM   #6 (permalink)
Normal on start up
You got it right. I recommend that you never drive on the public roads with everything off. Even the some of the best drag racers on this board, use competitive mode at the drag strip.
Old 05-31-2005, 02:32 AM   #7 (permalink)
blkZ06's Avatar
when you start up the vette, everything is on (ah and traction on)
hold the button down for 5-7 sec, you will see COMP mode come on the DIC
I run comp mode at the track (traction off, ah on)
on the street-just normal, unless you want to play
Old 05-31-2005, 03:38 AM   #8 (permalink)
on start up everything is ON
one click turns everything off, a light of a vette fishtailin will show on/around the RPM tach.
or hold it down until you hear a beep and on the DIC display will say "competitive mode"
on all start up I turn everything off, at the 1/4 I put it on Competitive mode...
I recommend not turning everything off, but not leaving the TC on, so "competitive mode" is the choice our cars have that option, many sports dont have AH, and the ones that do dont have the option to turn off TC and leave AH on, thats just stupid :oo:
Old 05-31-2005, 04:21 AM   #9 (permalink)
Send a message via MSN to Ronald Olson
Comp Mode
This sunday I came up on 15 Vipers Boy was that FUN it was a feeding Frenzy But it was fun . The Com Mode Works So Good The New Ones dont have much over the Z But Keep your RPM UP 4,500 or so
Ronald Olson is offline   Reply With Quote
Old 05-31-2005, 07:45 PM   #10 (permalink)
Normal on start up
Yes that is right. When you start the car, everything is on. If you hit the button everything is COMPLETELY off. Not recommended in my book. If you push and hold the button for 5 seconds or maybe even a bit longer, you will go into Competitive Driving which turns TC off so you can spin the tires as much as you want, but leaves AH on incase the car gets a little too far out of hand.
It has saved me on a couple of occasions and now I either drive with everything completely on or in Comp. mode.
Old 06-01-2005, 08:06 AM   #11 (permalink)
Originally Posted by IT L GO
You have 3 choices
All on
All off
Very true! Couldn't have said it better myself!
04 Z06 Mil Yellow Mod/Red - Donaldson Blackwing, Power Duct, Velocity Stack, Throttle Body By-pass, Hood Seal, Hurst Short Throw Shifter/Billiard Ball Knob, Eckler's Z06 Partition, Random Technology High Flow Cats and X-Pipe, 170 Thermostat, LS1 Edit, DuraStop Ceramic Pads and Drilled/Slotted Rotors.
HDRAMROD is offline   Reply With Quote
Old 06-01-2005, 10:20 AM   #12 (permalink)
comp mode
I wish there was a way to make the system default to comp mode on start up!
01 Z with a few bolt ons - 11th Corvette!
saber is offline   Reply With Quote
Old 06-01-2005, 01:00 PM   #13 (permalink)
holedgr's Avatar
Location: Where I have to be when I am not at a Z06Fest
Saber....there is a device at PYFC(supporting vendor) I believe, thta automatically turns it to comp mode.
Dave......give me a call, man.
-Tony
holedgr is offline   Reply With Quote
Old 06-01-2005, 01:08 PM   #14 (permalink)
-Tony
TracActive Controller is what it's called.It's made by Lap Trax. They have just lowered there prices to 99.00 for the Deluxe model
Old 06-01-2005, 01:25 PM   #15 (permalink)
You have 3 choices
All on
All off
Or how about
All on = "Drag race embarrassment" mode
All off = " Smack the curb or (worse yet) the wall" mode
Competitive mode = "Best bet most of the time"
What happened to my pic???
2002 Blk/Blk LS2 402, STS Twin Turbo, Spec V, HPTuners 2Bar Speed Density Tune by RalphP
RalphP is online now   Reply With Quote
TC/AH into Comp Mode - Interrupted? Blue Angel C5 Z06 - Grandstand 9 06-13-2006 11:59 AM
AH on vs Comp Driving mode roushraven C5 Z06 - Pit Road 3 02-23-2004 09:09 AM
How many drag racers use Comp/mode or others? george Racing 9 06-08-2003 04:04 PM
driving in comp mode frcfan C5 Z06 - Grandstand 14 03-11-2003 12:02 PM
Using Comp. Mode and the DIC thx2.net C5 Z06 - Pit Road 23 11-21-2001 08:48 AM
