Old 01-22-2003, 10:14 PM   #1 (permalink)
Downshifting by the book
downshifting on page 2-34 on the owners manual
Do not downshift into the gear shown below at a speed greater than shown in the table below
1st -50mph
2nd-74mph
3rd-101 mph
4th-130mph
if ya do the math, you will be about 1 mph over your rev limiter going into 1st @ 50. 74 in second is about 3-4 mph over the rev limiter in 2nd. And 101 is about 1 mph over the rev limiter in 3rd. Correct me if I am wrong. And even if the values were 1-2 mph under the limiter, why would you ever do such a thing. Your headed south on of the torque curve. And man, you are going to unsettle the car bigtime unless your a master blipper.
I think they maybe should a printed a Z06 specific manual.
BTW I was talking to an instructor at Justin Bell and he told me of a student going 4th to 1st. No floated valves, just one heck of a spin. Remember when in a spin, both feet in, when in doubt, both feet out [feather out that throttle if your in a corner] unless your feelin bonsai, then plant that right foot and pray for traction and smooth weight transfer.
Dr. E.
Dr.Electron is offline   Reply With Quote
Old 01-23-2003, 04:22 AM   #2 (permalink)
Flying Ace
Those instructions are there for the people who need the "lather...rinse...repeat" instructions on the back of shampoo bottles.
Old 01-23-2003, 05:09 AM   #3 (permalink)
I also like the part that says that you may have difficulty driving if you let the rpms drop below 500. I don't recall the exact wording but that is a reasonable (IMO) paraphrase. I guess the writers were related to those that wrote "remove before driving" on my sun screens. Apparantly there must have been someone who sued because they had an accident while driving with the sun screens up?? Like the lady who sues McDonalds for not telling her it might be dangerous to put a scalding cup of coffee between her legs.
z62jag is offline   Reply With Quote
Old 01-23-2003, 05:47 AM   #4 (permalink)
DR.
For the unwashed, in the hinterlands........what does both feet IN mean??.
I ASSUME out, means OFF the stop go pedals........?
Old 01-23-2003, 05:48 AM   #5 (permalink)
Vette TR, they also need to put a section in there about NOT trying to put a Big Gulp in the cup holder full under acceleration.....
Old 01-23-2003, 07:37 AM   #6 (permalink)
Both feet in is a trick I learned decades ago to safely combat and recover from a spin. Both feet in means left foot in on the clutch so as to keep the motor running, right foot in (as hard as possible) on the brake. Theorically, if you lock the brakes the car will go in a straight tangent from that point (altough it will be rotating around center). If the actual vehicle direction is safe (which it normally is if you do it early enough in the spin), this is a good thing. Much preferable to all those spins to the inside tire wall you see on TV. The downside today is that with ABS, you can't always get the results you want with this approach.
Old 01-23-2003, 07:53 AM   #7 (permalink)
Originally posted by Subdriver
Both feet in is a trick I learned decades ago to safely combat and recover from a spin......approach.
Sort of like "blow and go" and hope you do get an embolism.
gaijin is offline   Reply With Quote
Old 01-24-2003, 09:27 AM   #8 (permalink)
Re: Downshifting by the book
1st -50mph
2nd-74mph
3rd-101 mph
4th-130mph
Dr. E.
Good reading skills! I believe the 2003 owner's manual for Corvette has a Z06 shift table that lists 48, 69, 100 for first second and third gear respectively.
1fastdog is offline   Reply With Quote
Old 01-24-2003, 09:39 AM   #9 (permalink)
FiveOJoe's Avatar
That is what I was taught in dirt racing sprint cars as you started to spin. The idea was to get the car to loop quicker and then feather the throttle before it tipped over and before you reached the wall. Sounds easy, but very hard to convince your mind to do it!! When it worked it was pure artistry, when it didn't, it was ugly
Joe
sig by nutbush
Downshifting z06_23_45 C5 Z06 - Grandstand 16 10-31-2003 08:20 PM
Downshifting? MYZO6 C5 Z06 - Grandstand 35 08-16-2003 02:31 AM
downshifting and the whaaaaaaam! millcoupe01 C5 Z06 - Pit Road 9 05-21-2002 09:42 PM
Downshifting-who does it? Andy Cravens C5 Z06 - Grandstand 71 05-02-2002 12:56 PM
Downshifting transmissions FRISKY C5 Z06 - Grandstand 6 05-13-2001 09:47 PM
