Old 09-14-2007, 11:34 AM   #1 (permalink)
Failed emissions in MD - readiness monitors not set
Hi guys. I hate this emissions BS. What an utter pain in the arse it is. Anyway, it failed today with a 'OBD readiness monitors not set'. I don't drive the car much and I recently charged the battery. Is this the cause? If so, how long does it take to get 'ready', and how can I check the status? I have a Predator, but it indicated no errors.
Thanks for any help guys, I appreciate it as always
MY 2003, 733RWHP, 655RWTQ, forged 383, D1SC procharger, Kooks headers, heads/cam, LG coilovers, lots of other stuff
Chris Holmes is offline   Reply With Quote
Old 09-14-2007, 11:41 AM   #2 (permalink)
Re: Failed emissions in MD - readiness monitors not set
I had the same issue in Massachusetts. A few 30 mile trips caused it to finally be ready. It counts drive cycles so after driving 15 miles, shut it down and restart. That will make it ready even sooner.
And there is no way to tell if it's ready with a code scanner.
jdemeis is offline   Reply With Quote
Old 09-14-2007, 12:02 PM   #3 (permalink)
dwjZ06's Avatar
Chris,
It is a certain number of ignition cycles you need after a battery replacement. Call the ECS guys they can give you a work around I'm sure. You can start the car a bunch of times. By the way I heard through a friend that the Waldorf Test station does not even hook lowered vettes up they just send you around for a waiver. If it is not to far might be worth a try. Don
SIG by GR8 WHITE
Old 09-14-2007, 12:24 PM   #4 (permalink)
Originally Posted by dwjZ06 View Post
Chris,
Thanks Don, I might give that a try. What a pain this stuff is.
Old 09-14-2007, 12:26 PM   #5 (permalink)
You could always move.
j/k
vant is online now   Reply With Quote
Old 09-14-2007, 12:47 PM   #6 (permalink)
dwjZ06's Avatar
j/k
Thanks but, NO thanks Jake. You guys get freakin hurricanes there.
Old 09-14-2007, 01:58 PM   #7 (permalink)
CHRIS,
With the setup I assume you have- either high flow cats or no cats- you are going to have to buy O2 sensor simulators and complete a drive cycle after you install them. O2 sims have become a little tough to find and have become more expensive but you can still find them for under $100. If you google "drive cycle" you can print out the various conditions you need to put the car through to complete the cycle, and go for a ride. Try to complete a few cycles to be pretty sure you've done it. Then go get your sticker.
Jim
ST1100 is offline   Reply With Quote
Old 09-14-2007, 02:46 PM   #8 (permalink)
Thanks guys for the help. I'll let you know what happens
Old 10-10-2007, 11:15 AM   #9 (permalink)
Took the car back for retesting today, and it passed with no problems. Hurray!!!
Old 10-10-2007, 11:24 AM   #10 (permalink)
dwjZ06's Avatar
Good Deal Chris. Where did you go? What did you do to remedy the monitors? Don
Old 10-10-2007, 11:28 AM   #11 (permalink)
The error given was that the monitors weren't ready for testing (I disconnected the battery a while back). I just drove it for a couple of weeks or so, and that fixed it. I ended up taking it back to the same place I originally went to (Lindbergh Dr). This time though I talked with a young kid who worked there and he said I could have requested a waiver. Unfortunately I was already half way through the process, so I had to complete it.
Old 10-10-2007, 11:33 AM   #12 (permalink)
dwjZ06's Avatar
Good to know. I will need a battery soon myself. I will have to check the date of my next test. I am getting an Odyssey 925MJT battery.
Old 10-10-2007, 11:37 AM   #13 (permalink)
Is that the one that goes in sideways? Looked like a cool battery. Nearly bought one myself but looked a pain in the arse to fit. These Optima batteries are crap. I'm on my third one. I'd definitely stay away from them.
Old 10-10-2007, 11:43 AM   #14 (permalink)
dwjZ06's Avatar
Yes you can mount it anyway you want. It has a metal case to it but is only 26lbs which is 10 lbs lighter then the optima's. The bracket that they sell for it is another $43 bucks but hey if it lasts the 8-10 years who cares right.
Old 10-10-2007, 11:44 AM   #15 (permalink)
Let me know what it's like. I might end up getting one myself
Tire Monitors VNVETT C5 Z06 - Pit Road 11 12-23-2006 06:43 PM
Failed Emissions need help MrKool C5 Z06 - Pit Road 3 10-23-2006 03:19 AM
Failed emissions (not readys) need info! augydog C5 Z06 - Pit Road 14 04-01-2006 03:06 PM
Flat screen monitors ??? Big Red Machine The Garage 14 09-17-2005 12:31 AM
My Low Pressure Tire Monitors paid for themselves this week snakecharmer C5 Z06 - Grandstand 8 05-15-2005 02:18 PM
