Old 08-26-2008, 03:21 PM   #1 (permalink)
headlight gear questions
The driver side headlight gear started grinding the other night when I turned off the lights. I read about the brass gears available aftermarket. I have GMPP, so should I just take it to Tom Jumper Chevy or order the brass gears? If one just gave out is the other one far behind? Anyone who has gone through this already care to offer any thoughts?
redline water wetter,chevron techron,magnetic drain plug,andy's partition. 354.7 stock dyno
hugoagogo is offline   Reply With Quote
Old 08-26-2008, 08:07 PM   #2 (permalink)
spdrcrj's Avatar
Re: headlight gear questions
If you can get it fixed for free, I say do it that way. If they fail after your warranty, then you can do the brass gear change. JMO
Old 08-27-2008, 09:30 AM   #3 (permalink)
Call the Chevy dealer and ask them if they will install brass gears if you provide them. All covered under warranty.
TR '04 Z06 - Procharger P1SC by Next Level Performance
607 RWHP 507 RWTQ. Stock exhaust, Comp Cam 218/226 on 115 LSA.
MislMan is offline   Reply With Quote
Fs - Nib Bronze Headlight Gear Set (two) mph1972 Member Sales - Parts & Cars 1 06-25-2007 10:01 AM
3.90 gear swap Questions??? Gman2002Z06 C5 Z06 - Pit Road 2 08-01-2004 02:24 PM
NEED HELP - Headlight motor continues to run after headlight shuts. agentf1 C5 Z06 - Pit Road 5 06-25-2004 07:23 AM
4.10 gear questions? Bad64Vette Racing 5 03-12-2004 08:21 AM
3rd gear/steel shift fork/now 4th gear! MSiska C5 Z06 - Pit Road 14 07-23-2003 07:01 AM
