Old 07-09-2003, 05:38 AM   #1 (permalink)
vetteheadracer's Avatar
High Octane Fuel
Has this happened to you?
I have just been over to Sweden on holiday and here in the UK we have Unleaded Premium fuel which is 95 Octane. The US has 91 or 93 Premium (I can't remember which). Well I tried 98 Otcane in Sweden and it set the Check Engine Light!!
We have 98 Octane in the UK but I never tried it. I tried it in Sweden when at 1/4 full and filled up (only 'cos the 95 wasn't working).
After about 60 miles the Check Engine Light came on.
Checked the manual which said it might happen if you change Octane or Fuel Brand.
Refilled car with 95 Octane and immediately the Check Engine Light went out.
Has anyone else had this problem?
Life is not a dress rehearsal........
vetteheadracer is offline   Reply With Quote
Old 07-09-2003, 06:42 AM   #2 (permalink)
I ran 100 and 104 octane unleaded racing gas on the stock PCM numerous times with no check engine light.
Yours is the first time I've heard of a check engine light coming on for fuel.
Is it leaded fuel?
Old 07-09-2003, 07:00 AM   #3 (permalink)
J-Rod's Avatar
I have run Super 104 also, never had an issue. Like subdriver said, was the fuel leaeded?
J-Rod is offline   Reply With Quote
Old 07-09-2003, 09:27 AM   #4 (permalink)
Definitely Unleaded (well at least I think it was), the pump was defintely green.
The car ran fine without knocking or pinking eventhough the light was on.
Old 07-09-2003, 09:40 AM   #5 (permalink)
J-Rod's Avatar
might see if there are any codes stored in the DIC
Old 07-09-2003, 10:35 AM   #6 (permalink)
Are the octane ratings in Europe the same as in the US? Remember that some years ago (can't remenmber when it was, sometime since the 70s....I was in college then and have an excuse why I can't remeber!) we changed from the older (and higher value) Motor Octane to the average of Motor Octane and Research Octane. As I recall, this caused a reduction in reported octane value by around 5 points. You may notice on the octane label on some gas pumps indictaes (R+M)/2. Could this be part of the issue??
tdzee is offline   Reply With Quote
Old 07-09-2003, 06:22 PM   #7 (permalink)
Green pumps in the US are diesel.
Old 07-10-2003, 06:07 AM   #8 (permalink)
European Diesel Pumps are Black!!
The Octane rating we use in the UK is 95 RON and the car works fine with this no issues at all. My 1996 LT4 has always run fine on 95 as well.
One possiblility according to the manual is that if the gas cap is not fixed securely, it can casue fuel vapour escape which sets off the Check Engine Light. Therefore, it could be coincidence with the 98 Fuel, but I don't think so.
High Octane Gas Loadtoad The Garage 12 09-16-2005 06:35 AM
Fuel Additive / Higher Octane Fuel....? niphilli C5 Z06 - Grandstand 29 01-29-2004 01:28 AM
Switch from low to high octane fuel tables? FRISKY C5 Z06 - Pit Road 1 01-19-2004 12:22 PM
High Octane Delivery DJWorm C5 Z06 - Grandstand 8 10-18-2002 01:14 PM
100 octane fuel vs stock pump 93 octane - tested george Racing 17 07-15-2002 09:32 AM
