Old 06-19-2003, 12:22 PM   #1 (permalink)
How to Change Clutch Fluid?
I've seen many posts that recomend to change the clutch fluid after every time at the drag track. How is this done? I know there is a small resevoir next to the master cylinder with about a half cup of fluid. Please advise.
thanks.
coopz06 is offline   Reply With Quote
Old 06-19-2003, 12:40 PM   #2 (permalink)
get a turkey baster and remove all the fluid out of the clutch reservoir. Then wipe out the inside of the reservoir with a paper towel. Refill with some good brake fluid.
Old 06-19-2003, 01:07 PM   #3 (permalink)
What brand of brake fluid?
Old 06-19-2003, 01:18 PM   #4 (permalink)
Coop,
I use Motul 600F racing brake fluid. It is compatable with most conventional brake fluids.
The method decribed above is easy and free. However, it doesn't get all the fluid in the lines. A true flush is difficult and requires dropping the exhaust. If you do the above procedure often enough you will get all the old fluid out in a feed and bleed type approach. It will be pretty obvious as well. When you take the cap off and look at the fluid it will be likely be dirty. Remove it, put in new fluid and drive for a couple of days, then check again. If dirty (it will likely be dirty again), replace again. Repeat. I am now doing mine almost daily at the track.
Clutch fluid change (pics) hailskins666 C6 Z06 - Pit Road 30 04-14-2008 10:54 PM
Clutch fluid change question, plus shock install follies! saki302 C5 Z06 - Pit Road 2 05-09-2006 04:03 AM
Clutch fluid change questions. kmagvette C5 Z06 - Pit Road 9 05-03-2006 01:19 PM
How to Change Clutch Fluid? coopz06 Racing 7 06-20-2003 09:25 AM
Brake & Clutch Partial Fluid Change pmontelo C5 Z06 - Pit Road 16 07-12-2002 02:05 PM
