Anyone else's car being built these days. I'm sequence # 1045.
I can try to get a build sheet for you if Sonny says its OK. Guess I just need your sequence number.
Joe
This is my first post. I have been reading this forum for quite some time now, but never registered. Congratulations on your Z. My sequence number is 1180. I was told that my car would go onto the line July 19th (Friday) in the afternoon and would be done on Monday sometime. Does this sound correct? If so, I am deciding when I want to go down to BG. I guess the first thing I need to do is see if anything important is going on at work. If I can make it down, I hope to see you there. With my sequence number being so late in the day Friday, what does everyone think? Go on Monday? Thanks for any advice.
According to the production numbers, your car will be the 2nd car or so entering the Trim line on THURSDAY and should come off on Friday.
Here are the current production numbers I have from Sonny. The sequence # is the 1st car entering the trim line (about 10 hours long) on the date noted.
Approx 32 hours. with 10 hours on the Trim line. This is the only part we are allowed to see on our visits. Right now, 130 cars a day on an 8 hr shift, 150 per day on a 10 hr shift.
On 2001-07-01 18:09, Felkebg spewed forth this drivel:
Question: Start to finish, what amount of time does it take to make/assemble a Z06 on the line?
