Old 05-27-2002, 09:19 PM   #1 (permalink)
Malfunctioning turn signals
Has anyone had a problem with turnsignals malfunctioning? Occasionally mine just don't work, but oddly enough, they can usually be rester by turning on the emergency flashers for a few seconds. The dealer has replaced the turnsignal stalk and switch, but no success. Now they say they want to replace the emergency flasher switch but they arn't sure that will fix the problem.
Also, the low oil light has begun to come on even though the dipstick reads "full". Anyone have any ideas???
Thanks!
Tom Chapman
0260N4.0 is offline   Reply With Quote
Old 05-28-2002, 08:36 AM   #2 (permalink)
Send a message via AIM to Dash8Drvr
I regaurds to your turn signal problem, Had it too. The excessive heat under the dash broke the flasher unit. It happens to be one in the same as the hazards' flasher. It is covered under warrantee. the General is knowlageable about the problem. Bring it to the dealer. Make sure you tell them it is the flasher unit combination switch unit that is under the dash board. To the left of the a/c vent. where the button is. It fixed mine no problem.
Dash8Drvr is offline   Reply With Quote
Old 05-29-2002, 01:20 AM   #3 (permalink)
Thanks for the help! I'll pass this on to the dealer where my Z is currently being worked on.
Problem with turn signals weiner C5 Z06 - Pit Road 8 07-10-2005 09:06 PM
Intermittent turn signals??? Help!! Froggystyle C5 Z06 - Pit Road 15 01-05-2005 11:52 AM
turn signals work sporadically dezballs69 C5 Z06 - Pit Road 5 08-20-2004 04:28 PM
Front Turn Signals outlw C5 Z06 - Pit Road 5 07-20-2002 06:46 AM
Turn signals Z06 UK C5 Z06 - Grandstand 2 02-06-2001 01:32 AM
