Old 05-13-2005, 02:24 PM   #1 (permalink)
My Low Pressure Tire Monitors paid for themselves this week
Jumped in the Z Sunday to go to church and before I could get out of the garage I got a gripe about low tire pressure in the left rear. Parked it and took another car until I could check it. Took it in Tuesday and sure enough I had picked up a screw. The guy I took too did not even charge me to fix it; he must be a Corvette fan.
Definitely made the hassle and expense of getting them put on worth it, as otherwise I probably would not have noticed and might have ruined the tire if I had continued to drive on it. A pity GM didn't see fit to include these as standard equipment.
Eric
97-137 Saleen S281 Cobra, 07-075 Parnelli Jones Saleen S302
2007 Corvette Z06, 2006 Harley Davidson Screaming Eagle V-Rod, 2008 Harley Davidson Rocker-C, 2007
snakecharmer is offline   Reply With Quote
Old 05-13-2005, 02:57 PM   #2 (permalink)
Sounds great. He did demount the tire and plug/patch it from the inside I hope and then re-balance it.
Old 05-13-2005, 03:07 PM   #3 (permalink)
Nope, plugged it from the outside. I didn't detect any vibs at all. It felt fine.
Old 05-13-2005, 03:08 PM   #4 (permalink)
Wow. Cool!
Old 05-13-2005, 06:23 PM   #5 (permalink)
Our tires need to be patched from the inside also because of the speed rating.
Jack
04 Z06 MY/ModRed(SOLD)
04 Z06 Z16(SOLD)
Old 05-14-2005, 10:30 PM   #6 (permalink)
Which manufacturer did you get your low tire pressure system from?
Thanks,
Stumbo
2004 Commemorative Edition/Z16/#1498 of 2025
2004 BMW 530is
1997 Honda Accord LX (daily driver)
Stumbo is offline   Reply With Quote
Old 05-15-2005, 10:36 AM   #7 (permalink)
RocketSled's Avatar
Thanks,
Stumbo
There is only one. "The General".
Search for "Tire Pressure Warning" and you'll find all you need to know about this *most* excellent upgrade. The car already has the smarts to do this, you only need install the sensors and find a GM Dealer with a Tech-II scanner who'd be willing to take the 5 minutes requires to scroll through some menus and enable the function in your Z's RFA computer.
C6!
Old 05-15-2005, 12:02 PM   #8 (permalink)
Thanks for the info.
Old 05-15-2005, 02:18 PM   #9 (permalink)
NYCHASM's Avatar
Shop around before you buy the sensors. Prices vary significantly. They are well worth the expense.
Charlie
Sig schematization by EHS
Tire Monitors VNVETT C5 Z06 - Pit Road 11 12-23-2006 06:43 PM
Low Tire Pressure Monitor Training Problem USA #1 C5 Z06 - Pit Road 15 06-27-2006 02:37 PM
Can the limts for the Low Pressure Tire Monitor be changed? snakecharmer C5 Z06 - Pit Road 3 03-02-2006 06:26 PM
Low pressure tire sensors for 2004 Z06GCT C5 Z06 - Pit Road 37 02-16-2004 04:55 AM
Low Tire Pressure Warning System XFordGuy C5 Z06 - Pit Road 4 02-12-2004 12:39 AM
