Old 07-11-2008, 03:00 PM   #1 (permalink)
n00b question.. fuel filter
where is the fuel filter? lol cant find it
2003 z06 12k mi all stock
74 repu 13bstreetport t4 turbo t2 trans
www.myspace.com/predatorz06
predatorz06 is offline   Reply With Quote
Old 07-11-2008, 04:10 PM   #2 (permalink)
Re: n00b question.. fuel filter
It is up under the car on the drivers side rear area. If you look over towards the side of the frame you can follow the fuel lines to it if you have an 01-early 03 model.. If you are late 03-04 you have a FFS fuel system which is in the tank. Don
SIG by GR8 WHITE
dwjZ06 is online now   Reply With Quote
Old 07-12-2008, 08:40 AM   #3 (permalink)
RocketSled's Avatar
Also, don't be confused by the fact that there are *3* lines coming off the filter. The C5s use an integrated filter/regulator. There's a fuel in and a return on the side of the filter closest to the Tank, and the fuel feed to the front of the car on the side facing away.
Also, word to the wise... the stupid bayonette connectors are a pain to disconnect/reconnect. You're going to get some fuel spillage while you struggle with the damn things.
C6!
Old 07-12-2008, 10:51 AM   #4 (permalink)
Last C5's Avatar
Don't forget to remove the pressure from the system via the schrader valve on the fuel rail before disconnecting the filter assembly.
Last C5 is offline   Reply With Quote
Old 07-14-2008, 07:50 PM   #5 (permalink)
must be a late 03 i have then... so u have to drop the tank to do a fuel filter ?
Old 07-14-2008, 08:10 PM   #6 (permalink)
How do you do this?
Old 07-14-2008, 10:24 PM   #7 (permalink)
Last C5's Avatar
Originally Posted by ZO6 AL-X View Post
How do you do this?
Just pop off the drivers fuel rail cover and you'll find a cap on the front end of the fuel rail. Inside you'll find a shrader valve (like your tire valve stem). Wrap some rags around the area and push the center button to release system pressure. Changing the filter is messy enough with the pressure relieved, you don't want to do it with the system pressurized.
Old 07-15-2008, 10:04 AM   #8 (permalink)
Yep so if you do not have specific related problems you may want to pass this up for a while. How many miles do you have on your Z? What are the issues you are having? Any? Don
Old 07-15-2008, 01:59 PM   #9 (permalink)
car has 30k.. just thought normal maintance nothing wrong with the car
Old 07-15-2008, 03:01 PM   #10 (permalink)
I remember reading somewhere that the in-tank fuel filters are good for the life of the car....Not sure if this is true or not though....
Either way, I wouldnt replace it unless you are having a problem with a clogged filter....
Old 07-15-2008, 05:55 PM   #11 (permalink)
I would leave it if you are not having issues. I'll see if I can dig up the change interval for the 03-04's. It may be like the above posted no change needed if no issues.
Old 07-15-2008, 07:33 PM   #12 (permalink)
Thanks.
Old 07-22-2008, 05:53 AM   #13 (permalink)
lol yea i changed mine W/O depressurizing the system....getting fuel soaked was an understatment
01 Silver ZO6 (stock for now)
ZZO6 is offline   Reply With Quote
Old 07-22-2008, 08:07 PM   #14 (permalink)
I'll remember that now. Thanks!
DIY Fuel Filter swap SteveGel C5 Z06 - Pit Road 11 11-06-2005 12:37 PM
Fuel filter bumble bee C5 Z06 - Pit Road 2 09-20-2005 07:34 PM
Fuel Filter/Injector Question B_TRAPPS C5 Z06 - Pit Road 11 02-01-2005 12:23 PM
Where is the fuel filter located??? case2307 C5 Z06 - Pit Road 15 01-20-2005 10:13 AM
How difficult is it to get to the fuel filter? PerforminNorman C5 Z06 - Pit Road 2 07-19-2003 10:17 AM
