Old 04-26-2001, 05:45 PM   #1 (permalink)
I'm compiling a list of problems and fixes for common Z06 tweaks. Please post any problems you have had along with their fixes to be included in the document.
Thanks!!!
JC
N4C5S is offline   Reply With Quote
Old 04-26-2001, 11:40 PM   #2 (permalink)
Problem: Low oil warning in < 1500 miles.
Solution: Change the rings.
Problem: Antena comes loose.
Solution: Use a wrench to tighten it.
Problem: Something falls though the hole in your your glove box.
Solution: Squeeze the sides of your glove box in when you open it, and it will open all the way down, allowing you to retreive the stuck item.
Problem: Your seat doesn't move into its pre-programmed position.
Solution: Before putting your key in the ignition, hit the unlock button on your key fob.
Problem: You can't see the side of your car when parallel parking.
Solution: Program memory seat position #3 to have both side mirrors pointed down, so you can see the curbs.
Problem: TC comes on too much in dry weather.
Solution: Competition mode.
Problem: Rice-boy challenges you.
Solution: Blow his doors off!
C5David is offline   Reply With Quote
Old 04-27-2001, 11:03 AM   #3 (permalink)
MJM
Problem: 2001 Z06 with sticky brakes (brakes keep dragging after you release pedal pressure)
Answer: TSB 01-06-04-022
Part numbers for the new parts
Brake Booster - 18026035
Gasket – 10160244
2001 Z06
Museum Delivery
Thanks Tom Rogers
web site
www.corvetteforum.net/c5/mjm
MJM is offline   Reply With Quote
Old 04-27-2001, 09:49 PM   #4 (permalink)
Great, keep them coming!
JC
Old 04-28-2001, 03:59 PM   #5 (permalink)
Send a message via AIM to Felkebg
Problem: Head liner and driver side window defrost channel showing foam.
Fix: Carefully tuck back in and use exacto to trim other excess.
Problem: 6.5 quart approximate oil capacity does not fill to dip stick "full" line.
Fix: Add 1/2 quart to 7 and verify level.
Problem: White crusty coating on exposed engine parts when near salt water.
Fix: WD 40 coating before or after.
Problem: Storage of personal items in cockpit.
Fix: Use velcro and affix items within easy reach on back deck surfaces.
Problem: Don't like BSM's after purchasing them as options.
Fix: Remove by prying off with fingers and rub loose double sided tape adhesive. Use same product to reaffix if you change your mind.
Problem: Wheel blacking sprays all over sides of car. Leaves black specs.
Fix: Q-tip and acetone to remove spots then wipe any excess material from tires (if you use another product) as tires extend beyond fenders.
Felkebg is offline   Reply With Quote
common Z06 problems (I need help) boost pimp C5 Z06 - Pit Road 15 02-12-2006 12:02 PM
Installed Bassani X-Pipe - Common Problems! Silver Ghost C5 Z06 - Grandstand 8 11-26-2005 09:32 PM
Common problems ZEEOSIX VETTE C5 Z06 - Pit Road 21 03-10-2005 10:39 AM
problems,....list of GM Regional Reps pbadad The Garage 9 11-20-2004 08:12 PM
Most Common Problems drpipes C5 Z06 - Grandstand 19 09-03-2002 06:14 AM
