Old 07-29-2001, 05:21 PM   #1 (permalink)
I have noticed that when I push my throttle, it seems to chirp or hum right when I feel the engine kick in. Is this normal? It sounds like it is activating some sort of relay or something. What is it? It's kind of annoying. Otherwise, everything else is great!
TITANS/Z is offline   Reply With Quote
Old 07-29-2001, 05:24 PM   #2 (permalink)
Could be as you say, it's controlled by "throttle by wire" ????????
Old 07-29-2001, 06:07 PM   #3 (permalink)
Vette Doctor
c4c5specialist's Avatar
Hi there,
More information please, is it cold or hot??
rpm range???
gear????
Thanks, c4c5
Old 07-29-2001, 06:09 PM   #4 (permalink)
That's a new one. It might be like my "daylight-sensor-at-the-perfect-angle-to-flash-sunlight-in-my-eyes-at-every-bump" post.... [img]/phpBB/images/smiles/icon_smile.gif[/img]
Is it coming from the engine, or inside the cockpit by the pedal?
JC
N4C5S is offline   Reply With Quote
Old 07-29-2001, 11:24 PM   #5 (permalink)
Here's more info:
cold or hot -- both
rpm range -- all
gear -- any
It seems to occur when the engine starts to accelerate. It doesn't matter what gear or RPM. I noticed this when I broke in my car and varied my speed from 40 to 55 repeatedly. Try it and you might hear the chirp when the pedal gets pressed.
Old 07-29-2001, 11:29 PM   #6 (permalink)
I tried it, and I just got the whoop from the halltech, but I do recall before replacing my stock airbox this noise.
Have a friend stand in front of the car and listen near the airbox (don't run over said friend) and juice it slightly in neutral. I think the sound is the first gasp of air coming through those tiny holes in the airbox.
As a test, you could try removing the bottom of the airbox and repeating the test. Or just do what most of us do, replace the stock airbox... [img]/phpBB/images/smiles/icon_smile.gif[/img] More power [img]/phpBB/images/smiles/icon_smile.gif[/img]
JC
Old 07-29-2001, 11:58 PM   #7 (permalink)
I'll try it out, but it sounds like it is coming from under the dash, near the pedal. Thanks for your quick response!
Old 07-30-2001, 03:44 AM   #8 (permalink)
Vette Doctor
HI there,
Sounds like the intake disturbance that is being caused by the fact that c5 does NOT used an IAC motor.
Turbulence behind the cavity results in the whistle tip in, or the like.
I would have you specialist confirm this.
Best to you, c4c5
Procharger chirp... ndtpage C5 Z06 - Forced Induction & Nitrous 26 09-21-2006 09:48 AM
I can chirp Third gear now ! 99CORVETTEGUY C5 Z06 - Grandstand 7 07-16-2004 09:16 PM
Pedal Alignment Bob C5 Z06 - Pit Road 2 06-21-2004 06:55 PM
Part Vette, Part Chrysler, Part .... GroundFighter The Garage 9 12-23-2002 10:28 PM
Part Tuning Part Verification GroundFighter C5 Z06 - Tuning & Electronics 9 12-15-2002 07:01 PM
