hi everyone, I've got a 2004 Procharged Z06, had a new clutch last year with slave and remote bleeder. The problem is if I rev it to the redline even once I lose the pedal. After a few seconds it comes back, almost like it is boiling the fluid momentarily. I have flushed fluid and it is totally clean.
The car will drive allay to around the 5 k rev range without issue it is only when you really get on it. I was going to try a tick master cylinder, any good?????
Will this cure problem????
