Old 05-08-2003, 06:36 AM   #1 (permalink)
Pump to remove oil through dip stick?
Any recommendations? Something inexpensive, please.
I want to use it for track days.
Thanks,
"ROSSO Z"
Old 05-08-2003, 06:39 AM   #2 (permalink)
You might want to check out http://www.griotsgarage.com, they carry some of those types of things. I believe I saw that type of device in their catalog.
In fact, here is the link, it is about 100.00.
http://www.griotsgarage.com/catalog.jsp?&SKU=10186
NinjaZ06 is offline   Reply With Quote
Old 05-08-2003, 07:00 AM   #3 (permalink)
Oil has been extracted from boat engines through the dipstick for years. You can get an inexpensive pump from a boat place cheaper than the one in Griots.
Good luck
Juan Gonzalez is offline   Reply With Quote
Old 05-08-2003, 07:09 AM   #4 (permalink)
panzer's Avatar
You didn't read the fine print
"Please note, Oil/Liquid Extractor is not compatible with these models:
1999 - 2003 Corvette
1999 - 2001 TransAm
Late model GM/V-8 engines"
1985 BMW K100 m/c
Old 05-08-2003, 07:30 AM   #5 (permalink)
Send a message via Yahoo to pmontelo
Tempo Oil Boy
http://www.boatersworld.com/webapp/w...atalogId=10051
pmontelo is offline   Reply With Quote
Old 05-08-2003, 10:03 AM   #6 (permalink)
MAX
Rosso Z:
After the dealer overfilled the "Z" engine with oil, I also had the idea of just siphoning it out as I do on my boat. However, when I tried to run the siphon tube down the dipstick it would go only so far and would not reach the oil pan. I thought maybe a crankshaft journal was blocking it from going all the way in and I started the engine a few times and still no luck.
I have no idea what the obstruction is but you might want to check your's and see before you spend the $.
MAX is offline   Reply With Quote
Old 05-08-2003, 10:10 AM   #7 (permalink)
1999 - 2001 TransAm
No, I did not read the fine print. I was quickly posted it up there for review. Makes sense, you wonder how effective a pump would be on these models, due to the internal channeling in the pans. Seems like these baffles would make it hard to remove the oil by this method.
This may also make it diffcult for any of these others tpyes of pumps to potentially work, unless you can park the car in such a way to get all the oil to drain into the dip stick side of the pan.
Old 05-08-2003, 10:54 AM   #8 (permalink)
RC45's Avatar
I just drive the p!ss outa my car - keeping the revs above 3500 allows me to use 4 quarts in 2500 miles
Old 05-08-2003, 11:25 AM   #9 (permalink)
Juan Gonzales hit the nail on the head. Thank you Juan.
I looked up a local marine supply house and picked up a nifty $34.95 hand pump over lunch and will report back on how the device performs.
Oops! Thanks, MAX, but I jumped too soon. I left before the other threads were posted. I hope there is no obstruction................
Old 05-08-2003, 01:36 PM   #10 (permalink)
Here is the scoop I got from a local respected Corvette tech who works at a nearby dealer, Pohanka Chevy: The dip stick tube has no obstruction or the dip stick would not work. However, the tube narrows at the bottom to where it is just large enough for the tip of the dip stick to pass through. Hence the problems people have reading their oil level. So, if your extraction tube is too large, it won't fit. I believe the one I bought may be OK. If not, I will rig up some "drip tubing" and try that. That is drip tubing as in drip-watering plants, etc.. I will report progress on this most important project.
Old 05-08-2003, 06:41 PM   #11 (permalink)
MAX
Rosso Z:
I'll bet you're exactly right. Even though I thought I was using one of the smaller tubes supplied in the kit, I guess it wasn't quite small enough!!
Old 05-08-2003, 08:23 PM   #12 (permalink)
The continuing saga of the dip stick extraction pump.
I got my nifty marine supply house pump home and the 1/4 " OD tube would not go far enough into the dip stick tube. So, off I go in search of a smaller tube. After visiting Home Depot, Lowes, a nursery, I finally located some 1/8 " OD flexible tubing and a couple of fittings that seemed to be the right size. Got it home and all assembled and attempted to extract some oil. Well one of the connections was sucking air, but I kept pumping. After about 10 minutes a few drops dripped into the container. After about 1/2 cup was extracted in 20 minutes, Mobil 1 5w-30 began leaking out of every seem in the hand pump. Everything, including my hands had a light coating of oil on them by then. I decided to try another method another day and threw the whole thing into a large plastic garbage bag. I may change my mind, but I believe it will probably stay there.
I'm considering ordering one of those Harbor Freight jacks and learn how to jack the car.
Oh well. Some thimgs are not meant to be.
Old 05-08-2003, 09:27 PM   #13 (permalink)
Check out the MityVac.
http://www.thetoolwarehouse.net/shop/MIT-7200.html
Roger
2002 SVT F150 Lightning Supercharged Truck
13.43 @ 101.8MPH 4884Lbs STOCK
13.24 @ 103.9MPH 4834Lbs NOW
2002 Audi A4 Quattro Turbo (wifes car)
1994 Cavalier 4Cyl Winter Beater 30MPG
1989 Corvette Coupe ZF6 Z51 FX3 L98 with LT4 HOT cam 12.96 @109.3MPH daily driver
1987 Firebird Supercharged TPI 11.67 @118.6MPH in street trim
Corvette_Z06 is offline   Reply With Quote
Old 05-09-2003, 08:40 AM   #14 (permalink)
J-Rod's Avatar
You aren't going to get all the oil out of the dipstick hole. If I was worried about changing the oil, I would get a set of rhino ramps or use a couple of boards so I could get the car up high enough to jack. But, thats just me....
J-Rod is offline   Reply With Quote
Old 05-09-2003, 08:52 AM   #15 (permalink)
I'm taking my car to the track in a couple weeks. I read the warning about putting an extra qt in. This thread is about getting oil out-is it that important? In-other-words, are you going to trash the engine running an extra qt for a few thousand miles until the next oil change?
TX
NVGRWUP is offline   Reply With Quote
Red Dip Stick Frank Sr. Vendor Sales - C5 4 08-14-2005 10:51 PM
Dip Stick instal ??? DickieC.99 C5 Z06 - Pit Road 1 08-30-2004 10:51 AM
is the LS6 oil dip stock longer than the LS1 dip stick? SSpray C5 Z06 - Pit Road 2 05-26-2002 09:34 AM
Oil Dip Stick Richard C5 Z06 - Grandstand 19 05-05-2002 06:31 PM
Any tips on reading the oil dip stick? C5David C5 Z06 - Grandstand 7 03-27-2001 07:02 PM
