Old 06-12-2006, 02:02 PM   #1 (permalink)
TC/AH into Comp Mode - Interrupted?
My '02Z has a very annoying tendency to "forget" that I'm pressing and holding the Traction Control button in (yet another) attempt to get it into Competition mode. It seems that unless I'm sitting still or cruising at an exact constant speed, oh, and not turning the wheel, it won't allow me to engage Competition mode.
Anyone else continually peeved by this???
IMO, this is probably the biggest screw up on this whole car; in an effort to NOT fully disengage the electro-nannies and put the car into Comp mode I hold the button down, usually with no result. In the mean time, the car has no TC, no AH, nothing, and I have to push the button to reset and then push and hold AGAIN while trying not to upset the Queen Mum's tea.
Am I missing something here, or is this just plain stupid? Has anyone successfully programmed their way out of this mess? In a perfect world I'd purchase the car, set it to Comp mode, and never have to look at that stupid console button again!
'02 EB/MR Z
80% Track, 20% Driver, 100% Z
Old 06-12-2006, 02:13 PM   #2 (permalink)
robls6's Avatar
I've noticed on my car that sometimes while driving in 1st gear that it won't change settings. Perhaps it's a safety feature.
Old 06-12-2006, 02:26 PM   #3 (permalink)
I seem to recall that there was a device you could install to make Comp. Mode your default setting, not sure who sold it though sorry.
2002 Z06 Black/Black, fully optioned. Built 3-25-02, delivered 4-30-02. Chrome Z06 wheels/GHL Exhaust/Donaldson Blackwing/CAGS/Frame Savers/CLB/Rocker Panel protectors
WWK888 is offline   Reply With Quote
Old 06-12-2006, 04:32 PM   #4 (permalink)
RocketSled's Avatar
Sounds to me like you've got an intermittent connection. Assuming you have no problem setting it if the car is stilling still, the most likely explanation is a bad switch, or a loose wiring harness.
Pop the switch plate out (open arm rest compartment and pry up from inside edge) and reseat the connector on the bottom of the switch. May not do anything, but easy enough to try to make it worth it...
Also, I don't remember if the back of the Switch is open, but if it is, you might be able to squirt some contact cleaner solution inside (and then, work the switch a bunch of times, before heading out to try and see if it made a difference to while moving).
C6!
Old 06-12-2006, 04:34 PM   #5 (permalink)
Nithros's Avatar
Mine does it too intermittantly and it appears to be switch issues and nothing more - like when I'm not pushing it straight down but am pushing a little off to the side - like maybe it's getting worn out.
Nithros is offline   Reply With Quote
Old 06-12-2006, 05:37 PM   #6 (permalink)
They really should have done it the other way around. One quick push to turn on comp mode, so even if it happens by accident, the nannies are still there to look after you, and 5 seconds if you really want to go it alone.
Old 06-12-2006, 05:53 PM   #7 (permalink)
BTW, where do I get C5R washer fluid?
Old 06-12-2006, 06:16 PM   #8 (permalink)
I sometimes see the same thing on my 04, so I don't think you are alone here. The switch over to comp mode works most of the time, but sometimes it doesn't register. Like you, I end up cycling back to AH/TC On, then try again and it always seems to work on the second attempt. Only time that it seems to fail is when I have some turns within that 5 sec. wait. Wonder if it has something to do with trying to re-enable the AH while in a turn.
Tom
TnTs Z06 is offline   Reply With Quote
Old 06-12-2006, 10:18 PM   #9 (permalink)
The device you are speaking of is a "Laptrax Trac-active" controller. I am pretty sure some of our supporting vendors sell them. HTH
Jimbo
sig by GR8 White
Jim Lembo is online now   Reply With Quote
Old 06-13-2006, 11:59 AM   #10 (permalink)
Lightened battery, carbon fiber ashtray, heavy duty speedo cable, kevlar wheels, ceramic coated windshield, tinted HUD, r-compound fuel pump, titanium MAF, cross drilled and vented hood liner, ported fuse box, C5R washerfluid, tune by Col Sanders.
That is by far one of the better quotes I've seen!
Mike 01 Z06
::Gutted pup cats, cutouts, zip-tie mod SAE Numbers: 353.2 HP & 344.9 Torque
::Kooks headers, xpipe, G1 cam, underdrive pulley, double roller timing chain 406 RWHP /401 RWTQ
::Recent adds: HID's and seat bolster mod - best 0 cents I ever spent. B&M Ripper - One tough mofo to shift.
::Mod bug: HUD INSTALLED!! (the most terrifying install ever - bar none)
djstylze is offline   Reply With Quote
Comp Mode? dheller1 C5 Z06 - Grandstand 15 06-01-2005 01:29 PM
AH on vs Comp Driving mode roushraven C5 Z06 - Pit Road 3 02-23-2004 09:09 AM
How many drag racers use Comp/mode or others? george Racing 9 06-08-2003 04:04 PM
driving in comp mode frcfan C5 Z06 - Grandstand 14 03-11-2003 12:02 PM
Using Comp. Mode and the DIC thx2.net C5 Z06 - Pit Road 23 11-21-2001 08:48 AM
