Old 04-07-2006, 06:52 PM   #1 (permalink)
TCS/ABS codes fixed - Thank you MTI!!
Recently I've had the problematic ABS/TCS issues causing the lights to stay on and driving around without the use of them. It started after MTI installed a cam and headers for me late 2005.
Afterwards I checked the battery, harness, grounding cable on G-101, etc. I finally made an appointment with Jayson at MTI who found the problem in minutes. There was a ground cable on a battery harness that had worked its way loose or wasn't connected (not sure). Anyways, they took care of it and I haven't seen the codes.
Anyone who has had this problem knows it can be very frustrating as I had a few close calls driving without ABS. I won't say I'm an expert, but I've been through quite a few threads trying to find out. I also want to warn people from going out and dropping ~$1,700 on a brand new EBCM.
Anyways, thanks to this forum and the guys at MTI.
Mike 01 Z06
::Gutted pup cats, cutouts, zip-tie mod SAE Numbers: 353.2 HP & 344.9 Torque
::Kooks headers, xpipe, G1 cam, underdrive pulley, double roller timing chain 406 RWHP /401 RWTQ
::Recent adds: HID's and seat bolster mod - best 0 cents I ever spent. B&M Ripper - One tough mofo to shift.
::Mod bug: HUD INSTALLED!! (the most terrifying install ever - bar none)
djstylze is offline   Reply With Quote
Old 04-08-2006, 09:27 AM   #2 (permalink)
Send a message via AIM to injuner
Great to hear it was something simple! Bad grounds can cause all kinds of problems and they can be a pain to track down! Enjoy your code free Z!
Jonathan
2002 QS/ModRed
LG longtubes and x-pipe
injuner is offline   Reply With Quote
Changing Tire Size....what happens to TCS and ABS? MADN3SS C5 Z06 - Pit Road 5 11-15-2005 11:57 AM
Service ABS/TCS? vortech C5 Z06 - Pit Road 7 07-09-2005 10:33 PM
(Pic) figured Out My Service TCS/ABS/AH Error (I Think) BQuicksilver C5 Z06 - Pit Road 14 04-22-2005 03:17 PM
TCS codes Zeanster C5 Z06 - Pit Road 2 06-11-2002 07:23 PM
PCM, TCS Codes? 02ZO6 C5 Z06 - Pit Road 3 11-20-2001 07:55 AM
