Old 03-20-2006, 11:19 AM   #1 (permalink)
time for rebuild....need advice.
god dang motor is shot.....bad oil leak. the piston rings are shot. too much blow by. the gasket is actually pushed out under the valve covers. the car has a prochager. i want to rebuild it with stronger rods and low compression pistons. do i need to upgrade my fuel pump. ign amP? more flowing injectors. i have the 50lb. ones now and according to my tuner they are running out. we can't get it more fuel. is it worth rebuilding or just get a ls6 low compression block. thanks. kvn
t78fd3s is offline   Reply With Quote
First time at the track this weekend. Need advice. PointBy C5 Z06 - Grandstand 16 05-15-2006 02:04 PM
time for a new engine; soliciting advice ddl6289 Racing 8 05-02-2006 07:15 AM
Time for new tires, any advice? Gottinelli C5 Z06 - Pit Road 16 10-11-2005 03:42 PM
First time as a private seller need advice? burnout The Garage 3 04-18-2005 10:37 PM
Going to the drag strip for the first time - Any advice?? ADE 1000 Racing 7 10-24-2002 06:29 AM
