I used to work on the ABS/TCS/Active handling systems for GM. You are correct in saying that tires can have a negative affect on the performance of those systems. However, it really depends on the tire you choose. If you get a normal street tire, the chances are that the electronic brake systems will work pretty much the same. There may be some situations where the systems don't work perfectly, but they will still attempt to do the best job they can with whatever tires are on the car.
As for snow tires, there is actually a Goodyear snow tire made specifically for the C5's (maybe not the Z06, though). And this tire was tested to a point by GM for use with the electronic brake systems.
Regarding the use of reduced width tires, the width isn't so much of a problem as the aspect ratio. The aspect ratio is the center number of a tire size (35 and 40 in this case). This number means that the tire sidewall is X percent as tall as the tire is wide. For example, the front Z06 tire sidewall height would be 0.40 x 265mm = 106mm. If you reduce the width, the sidewall height goes down also, which reduces your rolling radius. The more the rolling radius changes, the more your speedo will be off as well as the electronic signals that the car's computers use. Whether the 10mm change in width is a big deal or not depends on your point of view. Personally, I don't think it's too big of a deal. The best thing to do is to find tires that also have a different aspect ratio along with the width to keep your same rolling radius.
350bob
'02 Black Z06
'69 Gold Camaro 350SS 4-sp
