Old 11-11-2004, 10:30 PM   #1 (permalink)
Tree sap on my Z
F ...... I got tree saps on my Z. All over the hood, front fenders and windshield.
I want to take care of it myself but its too freaking cold now. I am taking my car to Ziebart tomorrow.
SexyLex is offline   Reply With Quote
Old 11-11-2004, 10:37 PM   #2 (permalink)
Sorry to hear Bro
04 Z06 MY/ModRed(SOLD)
04 Z06 Z16(SOLD)
Old 11-11-2004, 10:41 PM   #3 (permalink)
'Dont know if I am over-reacting but I am so pissed off right now.
I've babied my car since I got it last 1 1/2 months ago.
Old 11-11-2004, 10:45 PM   #4 (permalink)
I can understand, i'd be P O too, since it just happened they should have no prob getting it off with no damage.
let us know how you make out
Good Luck
Jack
Old 11-12-2004, 01:10 AM   #5 (permalink)
I think the only way to get it off good is the clay it off. Did you have a recent wax job before this happened? If so that should help!
I would be pissed also!
I would call the guys at zaino and see what they say. They might have a easy way of getting it off.
quickone is offline   Reply With Quote
Old 11-12-2004, 03:33 AM   #6 (permalink)
DONT PANIC!
This stuff and tons of other almost invisable stuff gets on our cars everyday. It should be attended to asap.
Just make sure you use or someone uses proper stuff to remove it. DO NOT RUB the crap out of it. You will do more damage than good.
I suggest you polish and then wax the vehicle after. If it's too cold or you just don't want to do it, get a professional. Stop parking under trees! haha
Good luck, it will be better than it was shortly!
Peter
fastlightning is offline   Reply With Quote
Old 11-12-2004, 04:03 AM   #7 (permalink)
DO NOT CLAY TREE SAP!!!!!!
At least as your first step. EVER!!!!
STOP STOP STOP
Peter
Old 11-12-2004, 04:09 AM   #8 (permalink)
Here's some more info. I've tried them all. Depends on the tree and other conditions...
Each type of tree emits a difference type of resin (sap), at different times of the year.
Do you have any idea of what kind of tree sap is on your vehicle?
First, try "soaking" with a solution of water based all purpose cleaner, properly diluted, on a cool surface, in the SHADE!
Let it soak for at least 5 to 10 minutes, keeping it wet with the solution, don't go playing "rubby dub" or you might created some serious scratching,etc, which then makes more work.
If, after it sets and you have wiped it off and washed off with plain water, they are still there, move to the next step.
Since most "grease/wax/tar" removers contain a fairly high percentage of xylene in them, do not recommend their use except when preparing a vehicle for sanding and repainting..
Honestly, the safest hydrocarbon remover you can use is naphtha, used in many of the polishing and waxes used on vehicles, just under a different CAS#. Soak and let set, then wipe with a towel wetted with the naphtha.
Where do you get naphtha, simple, it is "lighter fluid" and will do nothing more than remove any wax or sealant on the clear.
Another, is plain old "rubbing alcohol", that's right, the stuff under most people's sinks.
It will not harm your finish; just use it the same way, "LET IT SOAK", DON'T GO GETTING ALL IN A HURRY AND RUBBY DUBBING!
If none of these work, and it turns out to be pine type trees emitting turpene use turpentine otherwise go to the clay.
You will get some scratching with clay, so be prepared to do some polishing after using it.
There are your "guide lines", as there are many types of trees, each with their own sap/resin emitted.
Old 11-12-2004, 06:13 AM   #9 (permalink)
Golffox's Avatar
I have much experience with Pine sap. First DO NOT attempt to rub out. Won't work without causing damage to the paint!
Use a sponge soaked in a mild soap solution and very warm (Not hot) water. Let it sit on the area for 10-15 mins. Then use Lestoil® in small amounts and wipe, do not rub.
Wax area several times after wards.
Here is a link (Sap removal) to try also. Relax, I know it hurts but it will all come out OK.
Powered by ANTIVENOM
Golffox is offline   Reply With Quote
Old 11-12-2004, 06:18 AM   #10 (permalink)
Registered User
Best Advice
FYI......George is very modest, and has won numerous Corvette Shows here in New York,.....his advice as always is right "on the money"........jimmy
pbadad is offline   Reply With Quote
Old 11-12-2004, 08:10 AM   #11 (permalink)
Thanks guys!!!
If it was a few droplets here and there I'd take care of it myself - even with the chilly weather here. It's really all over the car.
I dropped off the car at the detailing place this morning and the manager was shocked to see that much sap in a car. Hopefully they know what they are doing.
Old 11-12-2004, 08:31 AM   #12 (permalink)
Golffox, George?
Your zee is almost as shiny as mine....mayby more, but you're cheating with BLACK.
Have a great day!
Peter
Old 11-12-2004, 08:36 AM   #13 (permalink)
SexyLex, can't believe you have tree sap this time of the year in Michigan? Hope it turns out fine letting a pro do it. Let us know. Good luck.
Bob
Old 11-12-2004, 08:51 AM   #14 (permalink)
BTW, shop is charging me $200.
Get sap off
Wax/Polish
Paint sealant
Old 11-12-2004, 08:53 AM   #15 (permalink)
rwd
I would think any clearcoat-safe paint prep solvent would do the job.
rwd is offline   Reply With Quote
Tree Jumper Richard Branca The Garage 4 12-26-2006 12:56 AM
The Easter Tree. smook The Garage 7 04-15-2006 11:10 PM
Z06 vs. TREE pbadad C5 Z06 - Grandstand 5 10-28-2004 09:12 PM
Tree sap got me... any suggestions Stangklrws6 C5 Z06 - Grandstand 18 04-09-2004 11:13 AM
Freakin tree sap!!!! lasmith2112 C5 Z06 - Grandstand 12 09-21-2003 12:25 AM
