Old 05-03-2002, 07:33 AM   #1 (permalink)
What to look for on the walkthrough?
I'm picking my new Z06 up Saturday at the dealership. They are hauling it in from another city.
I'm looking for suggestions on items to look for on the car when I pick it up.
Thanks.
molmstead is offline   Reply With Quote
Old 05-03-2002, 07:52 AM   #2 (permalink)
Send a message via Yahoo to Rick1
Do a search on "delivery inspection"
I found 13 post on the sub.
Rick1 is offline   Reply With Quote
Old 05-03-2002, 08:46 AM   #3 (permalink)
Thanks Rick!
Old 05-03-2002, 09:03 AM   #4 (permalink)
Old 05-03-2002, 09:04 AM   #5 (permalink)
Get down on your hands and knees, and examine the underside of the lower sill panels on both sides. look for cracks and scraping damage...
Swirls scratches in the paint
Wheel damage, scratches, curbing etc...
Interior punctures, scrapes, etc.....
Owners manual is complete with Z06 pen & tire gauge
Take your time, and don't let them rush you......
Good luck
WE TOOK DELIVERY OF OUR 2002 Z06
AT THE NCM ON 4-15-2002
VIN 1G1YY12S825121664
Sequence # 022392
Z0000006 is offline   Reply With Quote
Old 05-03-2002, 10:16 AM   #6 (permalink)
See my previous replies to other threads on same subject.
Take a mirror to inspect undercarriage, if no lift available.
Do not accept after dark.
Take someone with you who can be objective.
Good luck.
"ROSSO Z"
Old 05-03-2002, 10:26 AM   #7 (permalink)
Make sure you look at the car inside under fluorescent lights and not outdoor in the sun. Otherwise, you will not be able to see paint scratches and defects. Take a portable halogen light with you if you have one.
Look over each wheel for defects in the finish, especially on the rim for curb rash.
Look under the car everywhere. Rocker panels, front air dam, etc. for shipping damage.
Check the engine compartment for proper fluid levels.
Check the inside for any interior damage.
Check that the trunk opens and closes properly.
Check to make sure that the rubber moulding around the windows is correct alignment.
Check the mileage to make sure it matches what is on the paper work, and if it has excessive miles, anything over 10 miles ask why and walk away. Someone has been driving it if it does.
Start motor and listen carefully. Make sure it will go into each gear. Ask to drive it before accepting delivery as well.
Do not accept delivery if it does not meet your standards. There are other cars on the market if this one does not.
My next will be an NCM delivery which will hopefully eliminate most of the shipping damage that happens.
Z06ROD is offline   Reply With Quote
Old 05-03-2002, 10:54 AM   #8 (permalink)
I would insist on a print out of the alignment specs for your new car!
The good news and bad news is that even with the specs right on there can be abnormal wear patterns, most common being front inside tread wear. (PREMATURE replacement of one to 4 tires: max cost 1400!!??) Then at some point you can research the forum for what all those numbers mean in English! And how they all work together and affect/effect each other!
2001 Z06 (1/5773), B/D 09/08/00, 99/133. TPW 9/11/00, Speedway White (1/352), modified TR/Blk int(1/137). Wet Okoles, Colgan bra, mirror covers, '02 stock air filter cover.
ruking1 is offline   Reply With Quote
june motor trend ls7 engine build walkthrough blackc6 C6 Z06 - Pit Road 0 04-28-2005 10:50 PM
