Old 01-28-2003, 08:15 AM   #1 (permalink)
What is your tire pressure?
Hello,
Curious to see what tire pressure setting other Z06 owners and drivers use for various driving scenarios with their stock tires. I typically run mine @ 30lbs for every day driving.
Thanks,
02BlueZ06
02BlueZ06 is offline   Reply With Quote
Old 01-28-2003, 08:44 AM   #2 (permalink)
NYCHASM's Avatar
30psi is the spec., as displayed on the tire placard. This, of course, is for your everyday street/highway/freeway driving. I'm sure other pressures are more suitable for the track.
Charlie
Old 01-28-2003, 09:05 AM   #3 (permalink)
MSiska's Avatar
30psi for everyday. 38psi for instructional driving at Summit Point Raceway. 40psi front, 22-24psi rear for fun time at the strip!
Old 01-28-2003, 09:21 AM   #4 (permalink)
Whatever your tire pressure, a good procedure to remember is that given a plus or minus 10 degrees temperature at fill up, that the PSI varies app 1 PSI. So if you are like most folks and check the tire pressure once a month, and say you filled it to 30 PSI when it was 85 degrees out and today it is 55 degrees out, chances are you are at least 3 PSI UNDER.
I run 30-33PSI on the street.
2001 Z06 (1/5773), B/D 09/08/00, 99/133. TPW 9/11/00, Speedway White (1/352), modified TR/Blk int(1/137). Wet Okoles, Colgan bra, mirror covers, '02 stock air filter cover.
ruking1 is offline   Reply With Quote
Old 01-28-2003, 11:16 AM   #5 (permalink)
Thanks for the replies.
I check my tire pressure year-round when the tires are "cold". Cold being relevant to the seasonal temperature.
02BlueZ06
Old 01-28-2003, 12:01 PM   #6 (permalink)
02BlueZ06
So if I understand your above post, your definition can have two meanings: 1. you measure tire pressure "cold" or not having been run 2. you measure tire pressure on the cold or colder days.
The other thing is that operating temperatures adds 3-4 PSI in all but the most extreme circumstances.
Again using a temperature constant after running if it measures 34 PSI then probably the cold PSI is 30-31 PSI.
So for another example, in a typical desert environment that can go from 40 degrees to 105 degrees you have a 65 degree or 6.5 #'s of variation.
Old 01-28-2003, 12:33 PM   #7 (permalink)
You're right. You obviously didn't understand my response or else you have nothing better to do than scrutinize the semantics and syntax of another member's post. Geez...you're a fair example of why I rarely post on this, or any other forum anymore. Duh, yeah, like, uh I only measure my tire pressure once a year on cold, winter-like days. Gimme a break!
02BlueZ06
BTW, there are no deserts in North Carolina, but I'm glad I have your reference in the event I ever am.
Old 01-28-2003, 12:37 PM   #8 (permalink)
02BlueZ06
And you are a real fine example of why it is good to clarify things. You may understand what you think you meant to say . But sir, you surely did not get it across! What did come across is the lack of manners.
Old 01-28-2003, 02:47 PM   #9 (permalink)
You r write! I not know what I mean to speak when I right. I hop you can reed thiss. I so glad you be hear to hep mee wif my American rightin'. Funny tho, yur repli tales me you understand a flame when u reed won, but yet you didunt understained my furst messege. Go fingure.
02BlueZ06
Old 01-28-2003, 02:59 PM   #10 (permalink)
Send a message via AIM to sigung86
How's bout bof yuse guys go to yer time out corners?
Dan
HallTech TRIC, B&M Ripper Shifter, MGW Anodized Pistol Grip shift knob, Stainless Screens, Illuminated Red Fuzzy Dice, Blue-yellow-green Scooby-Doo Steering Wheel Cover courtesy of my 5 year old grandson.
sigung86 is offline   Reply With Quote
Old 01-28-2003, 06:58 PM   #11 (permalink)
Kumho MX's on rear - 38 lbs
Kumho 712's on front - 36 lbs
JoeS is offline   Reply With Quote
Old 01-28-2003, 09:37 PM   #12 (permalink)
Send a message via AIM to Zoomin
Thanks to RPOZ06, I can now check my tire pressure while on the road. We installed air pressure sensors and reprogrammed the DIC! Why Z06's come without this is beyond me.
"'tis better to have zoomed and failed, than never to have zoomed at all." - Zoomin, 2001
Zoomin is offline   Reply With Quote
Old 01-28-2003, 10:08 PM   #13 (permalink)
NYCHASM's Avatar
A good question indeed, Zoomin.
My first thought would be that it's more important to monitor pressure with the run flats because a flat is difficult to detect. That said, I certainly can't explain why they didn't program it to work in our cars with "conventional" tires The only added cost would be the 4 sensors. Do you think the weight of the sensors was the primary reason they decided not to include this feature?? Could be, I guess.
Charlie
Old 01-29-2003, 07:47 AM   #14 (permalink)
They weigh slightly over an ounce, so I don't think that's it. If it is, then they were certainly scrimping.
Old 01-30-2003, 07:00 PM   #15 (permalink)
Sensors incompatible with goo
I think the sensor goes into the valve-stem and is imcompatible with fix-the-tire goo we get.
Gleb
Gleb Arshinov is offline   Reply With Quote
Tire pressure for 17's all the way around Jose Gonzalez Racing 5 08-25-2002 04:34 PM
Tire Pressure Help GroundFighter The Garage 0 08-04-2002 01:09 PM
Tire pressure for F1's Peterod45 C5 Z06 - Pit Road 12 05-22-2002 08:56 PM
Tire Pressure Jose Gonzalez Racing 2 08-15-2001 02:49 PM
Tire pressure...... ddle The Garage 12 07-11-2001 09:49 AM
