Tires
This is the tire I discussed at the spring kick off today.
Has anyone tried this tire? If so, how did/does it perform?
From three of the world's best roads to your most important ones - the roads you experience them on! The Eagle F1 GS-D3 is Goodyear's Max Performance radial that was developed in Europe for driving enthusiasts around the world who want more performance from their factory stock or aftermarket tuned sports cars, sporty coupes and performance sedans.
On the outside, Eagle F1 tires feature Goodyear's AAtrax tread compound molded into a distinctive wet weather racing-derived OneTRED directional tread design. And while the AAtrax tread compound's name emphasizes the fact that the Eagle F1 GS-D3 earns the highest "AA" Uniform Tire Quality Grade wet traction rating, Goodyear's OneTRED design combines three distinct patterns in the tread design to enhance dry and wet performance. A solid and continuous center zone maintains constant road contact to enhance straight-line tracking and initial steering response. Next, sweeping intermediate power transfer bridges use "virtual rib" technology to emulate racing slicks by delivering shoulder-to-shoulder tread contact to further enhance steering response and dry road cornering traction. Then sweeping aquachannel grooves, which are three times longer than the tire's contact patch, angle forward and out to the edges of the tread to avoid trapping air and water between the tire and the road to reduce noise while enhancing wet traction and hydroplaning resistance. And finally, the virtual ribs flow into the shoulder area to form long, stable shoulder blocks to grip the road during cornering and help resist the wear associated with aggressive driving.
On the inside, twin high-tensile steel belts are reinforced with spirally wound nylon to distribute the vehicle's load across the tire's footprint to provide high-speed durability and uniform ride qualities. Slightly angled body ply construction with high ply turn ups enhance steering precision and high-speed stability while exterior sidewall rim flange protectors help guard wheels from curb damage.
Goodyear Eagle F1 GS-D3 tires feature subtle black letters reversed out of a stylized black sidewall, and are available in a wide range of V-, Z- or Y-speed rated sizes in 55-, 50-, 45-, 40-, 35- and 30-series sizes for 15" through 21" rim diameters.
Click small images below to view larger.
Blackwall
Results from our online tire survey:
179 surveys submitted 748,842 miles reported
Dry
Traction
Wet
Traction
Hydro
Resistance
Snow
Traction
Cornering
Stability
Steering
Response
Ride
Comfort
Noise
Comfort
Tread
Wear
Surveyed Averages 9.3 9.2 9.1 N/A 9 8.8 8.6 8.6 8.4
Key: Superior (8.6-10) Excellent (6.6-8.5) Good (4.6-6.5) Fair (2.6-4.5) Unacceptable (0-2.5)
Would You Buy This Tire Again? Most said: Definitely (Average of 9 out of 10)
How Did This Tire Rank In Its Category? 1 out of 18 tires (Score of 8.9 vs best tire in category score of 8.9)
Compare This Tire to Other Max Performance Summer Tires
