Go Back   Z06Vette.com - Corvette Z06 Forum > General > Site Questions or Suggestions
Old 07-13-2007, 12:40 PM   #1 (permalink)
cbidwell's Avatar
New Posts - How to Reset ?
With the new system, how do you reset the new posts? On the previous system, when I log on and click "New Posts", it would show, say, 200 new posts. I would read/skim them, then exit. When I log on the next time and get back to New Posts, the old posts would normally be cleared and the system would show, say 2-3 posts.
On the new system, when I log on and read the 200 new posts, log off, then log back on later, it might say 210 posts - the previously read posts are still there. Is there a switch that needs to be enabled in my profile or setup to fix this?
Is anyone else having this problem?
Thanks.
Carter
2003 EB/Blk Z06
cbidwell is offline   Reply With Quote
Old 07-13-2007, 01:22 PM   #2 (permalink)
MikesZ06's Avatar
Re: New Posts - How to Reset ?
Carter, as embarrassing as it is to say, I'm still trying to figure out some of this stuff too.
I think the only way to 'clear' the posts from your screen after clicking the 'New Posts' link is to either individually click on each post (if multiple page, you must click on the last page) or if you click on the 'Forums' link to the left, scroll down almost to the bottom and click on the 'Show all threads as read' or something like that. 'New Posts' will then be starting from scratch.
There's probably an easier way but that's all I've found so far.
9.87 at 141mph
& 2007 Black C6 Z06
Old 07-13-2007, 01:22 PM   #3 (permalink)
G-Z06's Avatar
Send a message via AIM to G-Z06
Depending on how your cookies work.
It should say the following:
The threads below have not been updated since your last visit but still contain unread posts.
And have a list of the post that usually back up for a few hours before reseting.
GHOST MACHINE
F1 IDLE VIDEO/DYNO VIDEO/RACING CAMEO'S CAR
G-Z06 is offline   Reply With Quote
Old 07-13-2007, 11:33 PM   #4 (permalink)
I'm getting used to some of the new features. I'll point out in the "recommendations" post what I find/don't find.
Old 07-14-2007, 09:17 AM   #5 (permalink)
cbidwell's Avatar
Mike - you are correct. When I go to the forums screen and click on the "Mark Forums Read" link at the bottom, this resets the new posts. (Doesn't look like the site automatically resets it anymore.) I can live with that for now. Thanks!
Carter
Reset Please Help?? BIGMARSZ06 C6 Z06 - Pit Road 3 07-15-2006 01:46 PM
PCM reset question dsinned C5 Z06 - Tuning & Electronics 4 10-13-2002 09:23 AM
The site has reset again!! Rick1 The Garage 11 03-31-2002 01:01 PM
PCM reset quikdoc C5 Z06 - Pit Road 10 03-23-2002 10:40 PM
They have reset again!!! Rick1 The Garage 55 03-20-2002 02:59 PM
